  • Guests: 63
RoV IW3IPD (63)
01/12 RoV IW3IPD (63)
2n3055 driver
Platinum
Tue Feb 14 2012, 01:30AM Print
My ZVS is dead atm, and I have to get a one new MOSFET, and I was bored so I mad ethe 2N3055 driver, and I wasnted to increase output like this
I use:
35v 1000uF cap (all I have)
250v MKP 22nF very small caps
a RU47 200v 1a I think fast diode
The output is increase by a minuscule amount.
I also use 33Ohm resistor, and a 270Ohm resistor as I couldnt find the 240 and 27 ohm resistors which were called for in the schematic, for some reason this link I posted needs to use a 470Ohm resistor, (is 270Ohms good enough?)
Why isn't my flyback output being boosted?
Harry
Tue Feb 14 2012, 11:17AM
Harry Registered Member #4081 Joined: Wed Aug 31 2011, 06:40PM
One really simple circuit (needing only two parts) that uses a 2n3055 and can also drive the horizontal deflection transistors from televisions, is this one. The downside is that the arc is rather small but I think a great way to get started in HV.
1329218176 4081 FT134112 Img 0072
Sorry for the poor picture quality.
Platinum
Tue Feb 14 2012, 12:12PM
Hmm, I already have tried the ZVS, I'm goign to fix it, so I'm not very new, but I'm not very experienced.
I just want to make the arc like the improved 2n3055 driver in the link I posted.
Harry
Tue Feb 14 2012, 01:23PM
Ah right, I guess just order some new MOSFET's then, were you using the IRFP260?
