  • Guests: 38
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Is this a photomultiplier?How can I use it?
hsieh
Mon Feb 13 2012, 01:43PM Print
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
Is this a photomultiplier?How can I use it?What might be its original use?I found this on a local auction website and I cannot find any part number on the tube.
Thanks
1329140504 1412 FT0 P1000272
1329140504 1412 FT0 P1000273
1329140504 1412 FT0 P1000270
1329140504 1412 FT0 P1000271
Mon Feb 13 2012, 06:38PM
It looks to be a box-and-screen type PMT. From what I can see in your pictures, it doesn't appear to have many dynodes - the hemi-cylindrical backs of which I think we can see in your picture number 3.
As for the use of such a tube, fluorometry perhaps?
Wastrel
Mon Feb 13 2012, 07:29PM
Wastrel Registered Member #4095 Joined: Thu Sept 15 2011, 03:19PM
I would have expected a box and grid PMT to take up more space. This looks an extremely compact tube.
Things that will help. Measure the diameter of the top. In mm please. Carefully count the number of pins as well as any missing ones. This will tell us the number of connections and the base type. On the ring around the middle there seems to be some markings, see the last pic, something like RE??66.
Turns out what I thought was linear focused is actually circular cage. I'd guess something like a Hamamatsu R2066, but it is a guess.
hsieh
Tue Feb 14 2012, 01:50AM
Wastrel wrote ...
I can see RC2066 inside the tube,but I cannot find any datasheet.
Tue Feb 14 2012, 11:09AM
The datasheet for Hamamatsu R2066 is here: Link2
You can download the free Hamamatsu photomultiplier handbook here: Link2
NB: I expect you know already, but for the benefit of newcomers, do not switch on your PMT except in total darkness - or it will be badly damaged immediately.
Tonskulus
Wed Feb 15 2012, 04:51PM
Tonskulus Registered Member #1223 Joined: Thu Jan 10 2008, 04:32PM
I have also two photomultiplier tubes. Bigger one is FERNSEH VFS1050M.. still wondering if I can find any use for it.
Can't find any info about it tho.. it has 14 pins anyway.
