  • Guests: 23
11/29 Sonic (59)
11/29 kamelryttarn (47)
11/30 arnsfelt (46)
Vortex rings big and bigger.
1 2 3 4  last
Tesladownunder
Sat Jul 22 2006, 11:46AM Print
First the small one made out of a large can and a rubber glove and held over a smoke generator. Gives a surprisingly strong puff of wind. Used a 50% diameter hole cut in the base.
The big one is coming in after a few replies. (Wow, I don't take 200 pics in a day for no reason)
Peter
1153568768 10 FT0 Vortexcanmichael2
1153568768 10 FT0 Vortexcanjustin2
ragnar
Sat Jul 22 2006, 02:02PM
200 pics? This better be a bloody big vortex-cannon-doobiewopper. =D
Just curious also, what's your "smoke generator"? =P
Looks like some newspaper burning in a can of diesel to me, hehehe
Tesladownunder
Sat Jul 22 2006, 08:02PM
blackplasma wrote ...
Well it was larger. I used a compost tumbler 80 cm diameter by 90 cm deep that had been sitting as scrap in our backyard for years. Construction needed one day from start to finish with my 3 kids helping. An experience like herding cats really. Never the less finished and lots of pics taken. Fun was had by all for almost no cost.
Construction was simple and composed of blocking some holes and making others. The diaphragm was made of a rubberized picnic blanket (no I didn't put any holes in it). It is held on by several bicycle tubes. I knew I would find a use for them someday. Back tension is by an elastic luggage strap. Smoke is by commercial fog liquid (Dick Smith AUD$9.98), presumably glycol which is safe. We made a little heater from a spirit lamp from a chemistry set to heat it and it worked well, only occasionally catching fire. It was left in the barrel with a plastic cover over the aperture to let the smoke it build up.
Performance was great and it was able to make slow lazy rings or fast powerful one that fly across the yard some 15meters and rustle the trees. The sensation of this sudden whoosh of air in your face is most unusual particularly when you expect it but can't see it.
So the pics.. (just 196 to go)
Peter
1153598530 10 FT13391 Vortexbigmichaelflash
1153598530 10 FT13391 Vortexbigmeflash1
1153598530 10 FT13391 Vortexbigrear
1153598530 10 FT13391 Vortexbigteam
Marko
Sat Jul 22 2006, 08:45PM
Now it would be time to hook up your cap bank to it ala disk-launcher for propulsion shades
just kidding.. tongue
I like the second pic, the trace it leaves looks neatly stright..
Tesladownunder
Sat Jul 22 2006, 08:57PM
It is aimable after a fashion. Mostly just shoot from the hip though. Fast shots go surprisingly straight but will be disrupted by much in the way of wind.
I originally made this to investigate luminous events so I have yet to explore this with flammable materials. Once I have the knack of this then perhaps I'll add an alcohol spray and ignite it. Hopefully without making a fuel air bomb shades
Some more pics. I'll show the basketball ones next.
Peter
1153601829 10 FT13391 Vortexbigmichaelhereitcomes
1153601829 10 FT13391 Vortexbigchrishiding
1153601829 10 FT13391 Vortexbigchris2
Marko
Sat Jul 22 2006, 09:21PM
Fireballs sound cool if they are doable (I never saw something like that before.)
Problem could be to sequence the firing with igniting, I doubt you could hand-power such a thing anymore.
Burning gasses of any kind do tend to explode in closed space, but I doubt that will actually happen since hole is big enough to release the pressure.
Maybe you won't even need the additional propulsion since pressure of burning vapour will do the job itself..
Tesladownunder
Sat Jul 22 2006, 09:34PM
I am uncomfortable with igniting stuff in a vaporised condition even some distance away particularly as it could travel back down the track. I will have to think carefully about experiments in this area.
DC Cox has what he calls a KREW (Kinetic Resonance Energy Weapon) that I think is something like this powered by propane and can knock someone down at 100 feet if I recall.
I might even demonstrate my launcher when I do a Physics Dept Open day soon along with my other stuff.
Nevertheless, I still have 193 pics to go. Here are some basketball ones. A unique experience for a basketballer with a moving hoop and can't hold on to the hoop after a slam dunk confused
Peter
1153604044 10 FT13391 Vortexbigmichaelbasketball
1153604044 10 FT13391 Vortexcanjustinbasketballshot1
ragnar
Sun Jul 23 2006, 08:34AM
Is the KREW that big cannon that sets off car alarms? I've got a random video of it here, it's bloody brilliant!!!
***K-A-B-L-A-M***.... *echoes for another minute* *people cheer* *car alarm blares*
Sun Jul 23 2006, 07:37PM
I also thought about ignighting a ring but all the smoke rings (with some kind of fuel in them) by shooting them at a torch. I don't think I will because all the smoke rings I make leave a pretty thick trail of smoke right back to the garbage can that I shot it from. The thought of it exploding is not a happy one.
Tesladownunder
Wed Jul 26 2006, 11:49AM
This ghostly apparition in front of me is a slow travelling and thinning vortex. I reckon if I had put this in Mystery photos before I would have had a few people puzzled.
Once they travel far enough they become wider and thinner and in the second pic is about 6 feet in diameter. The camera was remote triggered since not enough hands on deck.
I now have a commercial smoke generator which is much more effective even on this windy night.
Peter
1153914564 10 FT13391 Vortexbigghost
1153914564 10 FT13391 Vortexbig6ft
1 2 3 4  last
