  • Guests: 25
  • Most ever online: 441
    Guests: 441, Members: 0 on 01 Oct : 16:32
GhostlyFigures (36)
10/05 GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
10/07 Pyromaniac (34)
PC Psu series tank Heater problems
Davebmx
Wed Feb 08 2012, 09:57AM Print
Davebmx Registered Member #4394 Joined: Mon Feb 06 2012, 07:43PM
Hi everyone I have built a very simple induction heater according to Dinges specification in an attempt to better understand induction heating and simple electronics. I built a Variac and connected it to a 230w fan cooled psu that uses the tl494 chip. I then replaced the frequency modulation resistor with a 200k pot. I also soldered some leads to the chip to allow it to be powered by a 12v gel cell. I have connected the 12v leads to a small motor and can get it to turn with an input of 30v from the variac and with positioning the pot at about 80% throw (so 160k ish?). When i connect my series tank circuit using 13 0.15uF/440Vac Capacitors and a work coil consisting of 5 turns of 5mm copper brakline. I have however wound the work coil internally to create a bore heater arrangment. However i am unsure about how to go about getting the heater to heat anything now. What should I test first? Should I solely connect a wound toroid and see if it creates an inductance field first? How should I increase voltage compared to the frequency of the pot? If anyone can see any glaring failures in my set up I would be very grateful for the assistance! Also at around 30v (the voltage and frequency arrangement thjat makes the motor turn) I can hear a whining from the power supply that changes pitch with input from the pot but it dissapears above 30v. Is this normal? Also I have bothe powdered and ferrite toroids.
19
49
42
27
