  • Guests: 38
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Heatsinking 1W surface mount LED's
Alex M
Mon Feb 06 2012, 05:11PM Print
Hi, I was wondering how I would go about heatsinking these high power surface mount LED's in the pictures below.
1328548120 3943 FT0 Dsc 0728
1328548120 3943 FT0 Dsc 0727
1328548120 3943 FT0 Dsc 0731
I had one running off of a 12v battery during a power-cut last night and I noticed with-in 5 minutes they get too hot to touch. They are 2.2v each and 400mA max so I used a high wattage 30 ohm resistor in series to limit current. It was drawing around 385mA with the 30 ohm resistor.
What sort of heatsink do I need and how would I mount one of them to it? The one I had running is soldered to the underside of a piece of strip-board with copper traces but obviously that is not enough too keep them relatively cool.
Thanks.
Wolfram
Mon Feb 06 2012, 05:20PM
Do you have a part number or a datasheet? Datasheets often give mounting tips. High power LEDs are most often mounted on aluminum substrate circuit boards, and bare boards are cheaply available on dealextreme and other similar sites. I could not find anything smaller than a 100-pack Link2 , and they are probably made for a different kind of LED, so this is not an ideal solution. You could also try soldering it directly to some thin copper sheet, just be careful not to overheat it.
Alex M
Mon Feb 06 2012, 05:24PM
Wolfram wrote ...
Thanks, I did look in the data-sheet but could not find anything.
VLMK71 series from Vishay.
What about a small aluminium heatsink, can I solder the larger solder pad directly onto that? Also is thermal paste needed?
1328548996 3943 FT133712 Dsc 0735
Wolfram
Mon Feb 06 2012, 05:37PM
Good luck soldering to aluminium. I know it can be done with some special solder and flux, but it's not something you can do with regular solder.
You wouldn't need thermal compound if it was soldered to the heatsink, just make sure the biggest terminal on the underside of the LED is the one soldered to the heatsink as this is the terminal that heat is dissipated through.
Mattski
Mon Feb 06 2012, 06:54PM
Another option for cooling surface mount LED's is to mount it on a two-sided standard FR4 board and use a bunch of vias to conduct heat from the LED side to the other side, where you can put a heatsink. For best performance it will be a thin board with thick copper and large copper areas on both sides. You want to do this for the larger pad because you can see this is the one the die is mounted on.
It's not as high performance as the metal core PCB's but you can have it built in any PCB house pretty cheaply.
Cree has some info on it for their LEDs: Link2
Pinky's Brain
Mon Feb 06 2012, 09:27PM
There are thermally conductive two component glues as well, for instance :
2Spoons
Mon Feb 06 2012, 09:51PM
Adapt something from here Link2
Thermal vias in thin FR4 work well - sweat the pcb to a copper heatsink. I've also done it using double sided Kapton flex pcb, also sweated to a copper heatsink.
If you need to mount a lot of LEDs, its not hard to get MCPCB made especially.
