  • Guests: 54
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
69mm Electric Ducted Fan, 2.8 lbs Static Thrust...
Sat Feb 04 2012, 02:44AM Print
this is one of my cooler projects!
1328323469 2431 FT0 Fan1
Rotor is 69mm in diameter.
1328323469 2431 FT0 Fan2
1328323469 2431 FT0 Fan3
It can draw 14.8 volts at 55 amps... so long as its cooled well.
1328324086 2431 FT1630 Fan4
1328324086 2431 FT1630 Esc1
This is my Phoenix ICE, 50 amp ESC, and its a data logger too.
1328324086 2431 FT1630 Reciever
1328324086 2431 FT1630 Stuff
Legit_bacon
Sat Feb 04 2012, 07:11PM
Legit_bacon Registered Member #4034 Joined: Thu Jul 28 2011, 10:41PM
Holy s*** that's awesome!
What are you intending on using it for? Or are you a remote controlled plane hobbyist aswell?
AndrewM
Sat Feb 04 2012, 07:56PM
The project is... purchasing a fan and ESC?
So mission accomplished then?
Electra
Sat Feb 04 2012, 10:22PM
That’ll be 2.5 minutes flying time then if you can use nearly all the batteries capacity, and about the same power as an average vacuum cleaner motor. Are you building a quad with some more of them?
I take it this is for the flying robotic challenge, seen your other posts on it, lot of respect to you Patrick for taking on what is such an immensely difficult task.
Sat Feb 04 2012, 10:31PM
AndrewM wrote ...
well, spending money, mission accomplished there too!
it ran for 13:30 at 25% throttle, by calculation it should run for about 3 mins at 100% i think...
Electra wrote ...
I was planning on making a tri-copter, or maybe a bi-copter, but im still doing the math on the free body diagram. I wanted to use the above ducted fan, but its throttle response (spool-up time)is too slow for my PID/Kalman loops, so i think ill just use a 8 inch prop with a fiberglass/CF duct wrapped around it. Yes it is for IARC mission 6 this year, i got the flight club up and going on campus too, so ive been busy... i have calculus 121 class too.
Carbon_Rod
Sun Feb 05 2012, 12:13AM
The KV of these ducted fans is usually double that of regular out-runners for a prop setup.
These are great for small high velocity airplanes, but do not perform well for vectored thrust setups.
That battery's days are likely numbered if the ESC isn't setup to regulate the drivers.
Cheers,
Sun Feb 05 2012, 12:39AM
Carbon_Rod wrote ...
Cheers,
It will cut out, yet keep the recieverand servos going, so the battery will be quite happy.
Anyway, im going over to a Power 10 E-Flight with a prop 10 x 3.8... that ducted fan just wont respond fast enough to be useful in this app, even at 40,000 rpm.
Carbon_Rod
Sun Feb 05 2012, 05:49AM
Most EDF VTOL platforms have an inertia control lag issues:
A 4 cell pack tends to allow EDF units to actually reach the correct rpm for the turbine.
1328419638 65 FT133595 4cell
Have you considered a small variable pitch quadrotor with a low center of mass?
You could try 4 large belt drive helicopter booms with tail rotors, and fast brush-less mini servos. That way the single engine rpm stays almost constant, and movement can be very rapid.
Sun Feb 05 2012, 07:14AM
My fan is reccomended for 3 cell or 4, but no more, i think theyre just to slow and E hungry. a 10x3 or 12x3 prop would give better hover dynamics.
Killa-X
Sun Feb 05 2012, 05:13PM
I know in battlefield 2, vertical take off jets had a turbine in the back...once in the air, it rotated 90 degrees, to turn into the main propulsion jet. Im sure one could do similar with a vtol, to move quicker :)
