  • Guests: 41
M.A.D. (32)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Piezo inverters and glow discharge plasmas
Thu Feb 02 2012, 06:40PM Print
Hi all.
Has anyone had any success getting two or more of these inverters to run with a frequency offset of a few hundred Hz?
I can't be the only person who has wondered about using them for glow discharge plasma experiments, in particular for building a solid state vacuum pump.
-A
Pinky's Brain
Fri Feb 03 2012, 02:10PM
Solid state plasma vacuum pump? So you mean you just have a barrier discharge tube with a positive grid at the high pressure end to attract the heavy ions and resupply them with electrons and a negative grid at the low pressure end to trap the electrons? Never heard of that, got a reference?
I don't see the relation with piezo transformers though ... they're compact, but I don't see why that would make them especially good at it.
Fri Feb 03 2012, 11:22PM
By 'solid state vacuum pumps' do you mean thin film getters, as we see inside the glass of some thermionic valves, André?
Pinky's Brain
Sat Feb 04 2012, 12:42AM
I think he means something like the paper "Aerodynamic flow acceleration using paraelectric and peristaltic electrohydrodynamic effects of a one atmosphere uniform glow discharge plasma" (no free version available).
Sun Feb 05 2012, 12:47AM
Yes, something like this.
The reason why I am attempting to use piezo transformers is that the peak currents can be much higher than conventional wound transformers.
Not least they are a lot lighter, and tend to fail gracefully i.e. lose output rather than catching fire like CCFL transformers do.
-A
