  • Guests: 36
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Question about precise Current measurement tools (~10kA range)
Mathias
Mon Jan 30 2012, 10:27AM Print
Mathias Registered Member #1381 Joined: Fri Mar 07 2008, 05:24PM
I'm in search of the possibly "best" Current monitor / Rogowski coil on today's market.
My question would be: Is there any alternative to a Pearson Electronics current monitor ? (For pulsed current application. In our experiment, we are trying to measure the current of a 100-200kV "fast" discharge into a load of around 10 ohms, underwater)
Ion physics corp, offers similar. But that device's usable risetime for the 20kA range is longer. (preferably 20ns or lower)
We also consider the use of Rogowski coil, for it's inherit greater frequency range at the cost of measurement accuracy (sensitivity to conductor placement) and the need for an active integrator.
Mon Jan 30 2012, 11:14AM
These guys make custom Rogowski coils and preamps, they may be able to help. Link2
Mon Jan 30 2012, 11:15AM
This paper describes a coaxial capacitive divider for fast pulse measurement with a 10Ω water line and might be helpful.
Jin-Liang Liu, Bing Ye, Tian-Wen Zhan, Jia-Huai Feng, Jian-De Zhang, and Xin-Xin Wang
Coaxial Capacitive Dividers for High-Voltage Pulse Measurements in Intense Electron Beam Accelerator With Water Pulse-Forming Line
IEEE TRANSACTIONS ON INSTRUMENTATION AND MEASUREMENT, VOL. 58, NO. 1, JANUARY 2009 161
Pinky's Brain
Mon Jan 30 2012, 05:45PM
Don't coaxial shunts operate in that range? (Although I can't quickly find a manufacturer, Haefely's cage shunts get close but not quite.)
Tue Jan 31 2012, 02:02AM
Took me a while to recover the odd name to search for:
Current Viewing Resistors.
For example, the K-2000-4 from T & M Research Products. Link2
2.5 milliohm shunt, so 10 kA would give you 25 volt output.
48 MHz bandwidth; 8 ns risetime.
E_max = 2000 J, so it could handle an impulse of 800,000 A^2.s
(for example, 10 kA for 8 whole milliseconds).
If 6 AWG wire can handle the pulse without insulation damage, so can that CVR.
I don't know if the CVR also has a current limit due to Lorentz forces.
Years ago I toyed with the design of a high-bandwidth coaxial resistor,
using a thin-walled cylinder of stainless steel as the resistive element.
A patent search might be in order.
A 1/400 ohm shunt resistor must have ESL on the order of 20 pH to have a L/R time constant that short (without frequency compensation). Perhaps compensation is the practical art, just like scope probes.
This reference gives some background and ideas. Link2
