  • Guests: 32
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Small Robot Radar for Proximity detection....
Sun Jan 29 2012, 04:14PM Print
does any one know of a 100 USD or so devicethat can range out obsticals for ground and air bots?
I was thinking about those parking aids for cars, but many of them are just ultra-sonic, which i already have. I was also thinking of using the sharp IR distance meters.
I cant use more than two ultrasonic devices beacuse of unsynced chirp-emission. the IR detectors are kinda iffy too.
Pinky's Brain
Sun Jan 29 2012, 05:29PM
Radar isn't directional enough ... wavelength and all.
Light, THz radiation or ultrasonics are your only option. The Lidar module for the Neato XV-11 has been hacked but it's more than 100 bucks.
Sun Jan 29 2012, 09:17PM
Pinky's Brain wrote ...
I was thinking of mechanically scanning it...
Pinky's Brain
Sun Jan 29 2012, 10:59PM
Scanning doesn't allow you to bypass the diffraction limit.
Carbon_Rod
Mon Jan 30 2012, 04:48AM
Kinect work well indoors ($100 used):
Radar works in dust, but production units appropriate for UAVs are expensive:
Primitive coffee-can SAR radar projects are documented too:
Cheers,
Mon Jan 30 2012, 11:31AM
I just need to be able to see walls and wether a 8 inch dia circle is present or not, would scanning still not work, givin the typical freq?
Carbon_Rod wrote ...
Cheers,
Yep, the USC team used the kinnect at the 2011 IARC mission 6 event, they scanned my body, and could identify windows and doors( and decide if the were open or closed) and recognise human bodies and depth.
as for the radar, im not sure i can afford them.
and the SAR's ive been looking at, but your sources are better than mine so ill read those over carefully.
Pinky's Brain
Mon Jan 30 2012, 05:16PM
Patrick wrote ...
Theoretically If you're working in GHz range then 8 inch is just about doable with a good directional antenna ... for a couple of cm near the centre you would get no reflection. Dunno if NA on those coffee cans is quite good enough to be absolutely certain there's a hole or simply a slightly more radar transparent/absorbent material.
I assumed you wanted more resolution than that.
Mon Jan 30 2012, 10:36PM
I must build one of those SAR's !!!! you can see the slope changing with speed on the V-t graph! (first derivative) thats so cool!
Carbon_Rod
Tue Jan 31 2012, 05:58AM
SAR projects are quite time intensive, but some students re-purpose directional WiFi antenna to reduce build times.
If you want to get started in this area... there are plenty of 30m range Doppler Radar units at around $10 each
I became curious about the mdu1620 & HB100 units for an improved dead reckoning project, but none of the app notes really state anything meaningful about their internal design.
From a competitive perspective, I would recommend asking a faculty representative to help arrange "branded" sponsorship from Novelda. So far, I have only heard of one company (Hokuyo) that does not support student research. People become especially cooperative if their brand is credited for trouncing the competition in a televised event, or published works...
Cheers,
Rod
Tue Jan 31 2012, 11:03AM
the Hokuyo ones are what everyone one uses, but they have some sever limitations. almost everyone used the 2000 USD, and one used the 6000 USD one(at IARC #6), and they're prone to noise and low bandwidth, much lower than advertised.
