  • Guests: 23
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
PID Loops for SMPS's.
Sat Jan 28 2012, 08:47AM Print
Has anyone here on the forum used PID control loops for the feed back of our SMPS's?
Sat Jan 28 2012, 11:06AM
Unlikely as it may cause oscillations with reactive or even varying loads.
Electra
Sat Jan 28 2012, 12:09PM
Well kind of thought as the typical voltage mode typeIII compensation network had 3 terms it was already approaching something similar to a PID loop, though the proportional gain at dc, often seem to be set at infinite.
Apologies if I have got it wrong or misunderstood what you meant, have a lot to learn about power design myself.
Sat Jan 28 2012, 02:43PM
Electra wrote ...
Electra, you did get my correct meaning. However as for Sulaiman's comments, i fail to see why PID's would cuase bad behavior... my curiosity lies with how the typical C||(R,C) circuit that lays across the out and the in op-amp on all those IC's would be modded to accept A PID sYstem.
radiotech
Sat Jan 28 2012, 03:16PM
The PID could handle thermal regulation quite well, and if you think about it
the root of Ohms law is just heat handling. At least while we cant make superconductor
SMPSs.
Sat Jan 28 2012, 03:33PM
A PID can control anything, it is the general case of all linear control loops.
Proportional gain at DC makes no sense. It's the integral gain that does that. As soon as you set the integral gain greater than zero, you get infinite gain at DC.
The standard SMPS compensation circuit is equivalent to a PI controller, which is of course a PID with the D set to 0. The extra little capacitor across the whole thing isn't part of the PI scheme. It's just there to slug noise at the switching frequency, it is too small to affect the loop dynamics. (if you make it big enough to affect the dynamics, its effect is destabilising)
Lately people here have been experimenting with non-linear control schemes like bang-bang and delta modulation, and claim better transient response than linear PWM. One advantage of these schemes is, it's almost impossible to screw up the compensation because instability is actually the way they work.
Sat Jan 28 2012, 06:04PM
Steve Conner wrote ...
yep, precisly. a PID loop will always work (even without the "plant" devices being known), however there are more optimised solutions if the interior of the device can be defined.
