  • Guests: 36
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
3 phase VFD
haxor5354
Fri Jan 27 2012, 04:14AM Print
I got my self a 400w mitsubishi 3 phase VFD for free, but sadly my house doesn't run on 3 phase power
will it work if i just feed in 1 phase? and is it possible to convert 1 phase to 3 phase easily?
the model # is FR-A024-0.4K
radiotech
Fri Jan 27 2012, 07:31AM
I have a couple of these Mitsubishi units and they run just fine on single
phase 230 volt 60 Hz by connecting to the U1 and U2 terminals. Study your unit.
The 3 phase lines probably go to a 3 phase bridge, and is converted to DC to
run the unit. The rule of thumb for things made to run on single phase power
that were designed for 3 phase is derate the kilowatt output by 58%.
Did you get the manual? Those units are tricky with regards torque/speed/
ramping rate etc.
Any load, except a motor will give you nothing but trouble. They also
are very unforgiving of shorts and assorted flashes, etc, despite their overload foldback.
radiotech
Fri Jan 27 2012, 07:33AM
unit
1327649586 2463 FT133203 Freqtrol1
haxor5354
Fri Jan 27 2012, 02:09PM
ok I connected 220v hot to phase 1 and neutral to phase 2 ground to ground, and I barely get any voltage across the output and ground. certainly not 220v when i tested it with a 220v lamp.
Fri Jan 27 2012, 02:17PM
Like Radiotech says, it probably won't do anything until it's connected to a 3 phase induction motor. But at least the display should light up and show some sort of error message.
Also, in North America, any voltage between any domestic line and "neutral" is 110V. You need the two hots.
haxor5354
Fri Jan 27 2012, 02:30PM
Steve Conner wrote ...
oh i connected it through a 110 to 220v transformer. so it can't even control a 1 phase induction motor?
Fri Jan 27 2012, 02:47PM
Nope, these things are for 3 phase motors only as far as I know.
radiotech
Fri Jan 27 2012, 07:13PM
The manual for your unit is here : Link2
