  • Guests: 52
02/03 Bauerb2 (36)
02/04 Fabio (46)
02/04 Corey (35)
Comparing power transformer ferrite materials
Kizmo
Wed Jan 25 2012, 07:24AM Print
Im having some difficulties with comparing different ferrite materials. Contestants are:
Epcos N30 Link2,property%3DData__en.pdf
Ferroxcube 3c90 Link2
If cores are same size and operating conditions are 300mT, 50kHz sinusoidal drive waveform. Which One of these cores have larger core losses and by how much.
Wed Jan 25 2012, 07:28AM
OK, ok let me look...
1327478701 2431 FT1630 Ferrite
These to graphs are from you 3C90 material, i dont see their equivelents on the epcos datasheets.
Kizmo
Wed Jan 25 2012, 08:17AM
Thats the problem :(
They seem to use very different methods for listing core losses and i have no idea how these numbers compare.
Wed Jan 25 2012, 08:21AM
if they dont list the loss conditions, then theres nothing to compare.
Im suspicious that the EPCOS maybe crap material, for that very reason. Or perhaps not meant for power usage. Your sure you have the complete datasheet for the N30?
Kizmo
Wed Jan 25 2012, 08:29AM
Epcos uses relative loss factor on their datasheets all over
Wed Jan 25 2012, 08:57AM
Kizmo wrote ...
I really dont think that allows a comparison or is an equivlent (even with some fancy math). in any case, for the 3C90 material... 300mT, 50kHz you can expect about 500kW/m^3 of loss, so take your core volume and multiply by that. Youd would want to keep the ferrite temp at 90C other wise (above or below 90C) your loss will increase.
i prefer the TSF-50-ALL material, but i dont know your application. (50ALL would also yield about 500kW/m^3, but i dont know your temperature dependence, from 40C to 100C the loss rate is substantially flat.)
Imust admit 3C90 is a perfectly fine material, many use it. the N30 i have doubts about....
I think JPsmith might chime in too.
Kizmo
Wed Jan 25 2012, 09:36AM
T65 which is best Epcos power material for low frequency stuff (according to their app note..) has just tiny bit lower loss factor at 50kHz than N30.
Wed Jan 25 2012, 09:51AM
Kizmo wrote ...
Whats thier datasheet say for temp depencance, and what is your planned thermal profile?
Once you get to the question of:
this one is a little better than that one, you must account for the other factors that will alter the tiny gain you first sought.
Kizmo
Wed Jan 25 2012, 10:39AM
Here are two screenshots from epcos datasheets T65 vs N30 and one of their app note stated that T65 is their state of the art power transformer material for this low frequency range.
1327487510 599 FT133054 N30 1327487510 599 FT133054 T65
My application is large induction heater which will have transformer driven tank circuit. Reason why i want to compare these two materials from ferroxcube and epcos is that i have friend who made well working induction heater with transformer wound on 3c90 core and i happen to have same size N30 cores laying around.
3c90 in this application stays almost stone cold but i dont mind if i need to apply some airflow to my transformer.
Maybe i should just pop it in and see what it does.. cheesey
Wed Jan 25 2012, 07:27PM
Kizmo youshould call this EPCOS company and find out why they use tan sigma over u sub i or whatever, if they cant give you a striaght answer i wouldnt use their material in a system critical application.
