  • Guests: 46
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Ferrite Transformer Mounting Hardware
jpsmith123
Sun Jan 22 2012, 10:18PM Print
Well I've been going crazy trying to figure out the puzzle of how to clamp a ferrite transformer together so that it's not only secure and mechanically rugged but also flexible...and I came up with this:
1327269892 1321 FT0 Xformer Assy 1
1327269950 1321 FT0 Xformer Assy 2
This type of arrangement can be either stand-alone as shown, or it can be mounted vertically or horizontally to a chassis.
Luckily as it turns out, there's just enough room between the core and the bobbin for an 8-32 (or maybe a 10-32) threaded rod. In this case I used a nylon 8-32 threaded rod. The nylon seems to work good because it's somewhat flexible and forgiving, yet it has enough tensile strength that it can safely provide over 200 lbs. of clamping force (according to my crude calculations for two 8-32 rods).
Sun Jan 22 2012, 11:02PM
Your setup looks good, im a fan of the nylon too.
jpsmith123
Sun Jan 22 2012, 11:16PM
Do you think those nylon threaded rods will stretch over time and loosen up? I'm hoping they won't since I don't have them stressed very much, but I've never used nylon rod for anything before so I don't know.
Mon Jan 23 2012, 03:11AM
jpsmith123 wrote ...
Nylon wont have this problem, if i remember right. but some plastics, like PE will gradually change its shape continuosly... so im thinking your fine.
I suspect thats why nylon plastic is chosen for this purpose.
Electra
Tue Jan 24 2012, 05:00PM
The only thing I’ve noticed about the white nylon, is that is does degrade a bit with the U.V in sunlight, if ever that were an issue.
Try to keep the clamping force equal by tighten/loosening each bolt a little at a time, I’ve chipped fragments off smaller cores before realising how prone they are to damage when assembling or dissembling them, but being bigger yours may be more robust in that respect.
I suppose if you do have any problems with the nylon, you could always use a slightly longer frame and put the bolts on the outside of the coils, then use brass bolts instead.
Looks like you done a great job so far though.
jpsmith123
Tue Jan 24 2012, 05:32PM
When I assembled it, I was careful to tighten the wingnuts down evenly, by tightening one side a little bit and then the other side, going back and forth a few times. And I actually did not make them very tight, yet I was pleasantly surprised to see how well the ferrite core is held in place just by friction with the cpvc.
A real world test happened the other day when I accidently bumped it...pretty hard...and I knocked it over and it translated a short distance, and I picked it up after that and looked at it carefully and there was no apparent damage. If the ferrite moved at all (with respect to the cpvc top and bottom pieces) it was only a tiny if not imperceptible movement.
I was going to use brass if necessary but my first choice was to do it all out of insulating materials. (BTW thanks for the compliment).
