  • Guests: 20
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Seeing red with a green led ... why?
Sun Jan 22 2012, 10:03PM Print
I bought a green led to have a 'play' with, HLMP-CM2A-120DD Link2
(about 75% of theoretical max. efficiency !)
I'm running it at 20mA and it's very green and very bright.
Pressing the led on a fingertip, looking from the other side I see RED patterns, presumably blood vessels,
WHY?
In the dark I illuminated all kinds of stuff and for example red inks/pigments look grey/black so there's little or no red in the original spectrum,
is blood fluorescent under green light?
Tetris
Mon Jan 23 2012, 01:00AM
I'm guessing it is due to blood being very thin, with red blood cells not as frequent as the pigments in ink, so inks would appear dark (more light blocked out) while blood appears red (more light admitted).
Neet Studio
Mon Jan 23 2012, 01:41AM
Neet Studio Registered Member #4037 Joined: Fri Jul 29 2011, 03:13PM
I am going to go on a wild speculation that is likely to be wrong.
Is red the colour we see because red lights reflected off blood?
Or that blood absorb all other colours and only let red light passes through it?
The two modes are different. In this case, you are seeing the lights after it passes through your blood.
Also from here: Link2
>Below are images of a green LED for comparison. The peak is located at 559 nm, and its width is 24 nm.
>Students may be surprised to see that emission from a green LED is so wide that a bit of red is visible at one end of the spectrum.
And lastly how do we know if your blood is really red? wink
Mon Jan 23 2012, 01:48PM
The datasheet spectrum of the led indicates virtually no red in it's spectrum,
I think that is correct because as I mentioned red dyes/pigments appear black/grey in the green led light
and the 'brightness' of the red light through my fingertip is significant - not a vague trace
the red is so strong that you would not know the led was green.
I'll just mentally file it under 'miscellaneous data' until I research it more.
Mon Jan 23 2012, 01:56PM
Surely somebody here must have a green laser that they can try on themselves? That's guaranteed to have no red light in its spectrum. (Infrared maybe, if it was a DPSS smile )
Mon Jan 23 2012, 02:21PM
LEDs are not sources of monochromatic light as often quoted, There is indeed a very little bit of red radiation from green LEDs, enough to make the red visible when all other colors are blocked out.
Bjørn
Mon Jan 23 2012, 05:18PM
I have bright pure green LEDs that cause fluorescence in different materials so it might be that.
Checking the spectrum of two of my green ones show ouptut all the way from UV to IR. Looks almost like a white lightsource behind my thumb. So better check the output of the LED to be sure.
Mon Jan 23 2012, 07:57PM
OK, I just used a cd as a diffraction grating and to my surprise (vs. datasheet) my 'green' InGaN led covers the whole visible spectrum ... mystery solved..Thanks.
Mon Jan 23 2012, 08:22PM
E.TexasTesla Registered Member #4362 Joined: Sat Jan 21 2012, 03:44AM
Question. Could you see the freq. of the light by monitoring the input voltage with an oscope?
Next question does the freq. change if light is reflected back into the led? By your finger?
Hmmm..
Mon Jan 23 2012, 08:47PM
My 'scope bandwidth doesn't extend to the 100's THz so I can't answer that.
BTW
I see (!) where I made a significant mistake in interpreting the datasheet for the led,
the intensity scale for the led intensity vs. wavelength has a linear intensity scale,
whereas I believe that my eyes have a nearly logarithmic response,
so what looks to be negligible intensity on the graph is still quite visible.
