  • Guests: 29
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
MOT PSU
Platinum
Tue Jan 17 2012, 07:47PM Print
Well I got my hands on a MOT, enjoyed it arcs, but now I want to make a PSU from it, for my ZVS, all I have to do is knock the HV winding out?
Is the ration 240t primary and whatever turns on the secondary, say 36turns for 36volts? How much Amps at 36 would there be? 16A?
Turkey9
Tue Jan 17 2012, 11:50PM
You could put on two or three windings and measure the voltage output then divide by the number of turns to get the voltage per turn on the secondary. Then just divide your desired output voltage by volts/turn and you get the number of turns needed!
I doubt that the primary has exactly the number of turns as the voltage it was designed to run on.
Platinum
Wed Jan 18 2012, 01:04PM
Could my crappy ZVS circuit (not built by me) take 16amps at 36v?
Wed Jan 18 2012, 01:09PM
Can Jimmy's crappy truck carry a ton of gravel?
Your question makes about as much sense.
Platinum
Wed Jan 18 2012, 01:32PM
No. I guess not then.
m4ge123
Wed Jan 18 2012, 01:38PM
m4ge123 Registered Member #4118 Joined: Mon Oct 03 2011, 04:50PM
What FETs does your zvs have?
Platinum
Wed Jan 18 2012, 01:49PM
IRFP250.
The guy who built it for me ripped me off, he charged my £25~ and the zener's are proper crap (I had to replace them), the circuit is generally pretty flimsy and prone to short circuiting, the way it's been built.
HB
Wed Jan 18 2012, 03:02PM
HB Registered Member #4146 Joined: Tue Oct 18 2011, 02:01AM
I wouldn't say he ripped you off it worked when you got it and misuse leads to parts getting destroyed it happens. I don't think its fair to blame him for a crappy zvs unless you yourself can build better. That being said your zvs should handle 36 volts no problem provided its hooked up right whether it be a seperate supply for the gates and one for the power section or just 1 supply with the proper gate protection.
Alex M
Wed Jan 18 2012, 03:16PM
Just becuase a power supply can provide x amount of amps doesn't mean that is always the amount of current that will flow through the circuit/load you power with it.
For example I can power a 12v 0.1amp computer fan using a car battery which can supply 100's of amps when shorted yet the fan will only draw 100mA.
BTW for ZVS zeners I used these Link2 from maplins and they have worked fine.
m4ge123
Wed Jan 18 2012, 03:43PM
Your zvs can take up to 50 volts and might be able to take 16 amps with good heatsinking.
