  • Guests: 34
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Convair corp. and rocket propellant...
Tue Jan 17 2012, 08:50AM Print
I'm totally too druNk to walk, and have question....
watchign the history/military channel and went to wiki found this quote;
from here -> Link2
and heres the quote...
"The Convair Division produced its own airplane designs, such as several airliners, until 1965, when it shifted from these to airframe/aerostructure subcontracting projects for other companies. Convair also shifted more money and effort into its outer space products, especially rocket boosters. The Convair-made and cryogenically fueled Atlas missile ICBM for the U.S. Air Force had within just a handful of years become obsolete, and had been replaced by the room-temperature liquid-fueled Titan II missile and the solid-fueled Minuteman missile."
whats the differencew
cryo-genic / room temp, what do they mean?
EDIT": is one meaning liqiud hydrogen exposed to atompshere ? therefore pressure vessles (with great weight) become irrelevnt?
or do they mean kerosene, cause kerosene iz lame.
im driunk and confused...
Tue Jan 17 2012, 09:56AM
Cryogenically fuelled = liquid oxygen for the oxidizer. Fuel can be liquid hydrogen or kerosene.
Room temperature fuelled = nitric acid, dinitrogen tetroxide, etc. for the oxidiser. Fuel is usually hydrazine or kerosene.
You seem pretty well fuelled yourself, so maybe you should try drinking some liquid oxygen and lighting a fart.
Tue Jan 17 2012, 11:24AM
Steve Conner wrote ...
ATM that would be excessively dangerous!
yeah but it says the Cryo's were developed first, then they were later made obselete by the room temp ones? does that sound right? i would expect it to be the other way around, like the german V2/A12 development program...
Tue Jan 17 2012, 11:56AM
Yes, that's right. For a long time, they couldn't figure out how to stop fuming nitric acid from corroding the fuel tanks, and they couldn't find any other good room-temperature oxidiser.
So liquid oxygen was the next best thing and ICBMs had to be fuelled at the last minute.
After a lot of research, they came up with "Inhibited" red fuming nitric acid. Later still, a form of hydrazine was concocted that wouldn't freeze in winter. IRFNA/UDMH is now the standard storable propellant combination for missiles.
It's all in the book "Ignition" by John D. Clark, now out of print but available from your local file sharing network! :p
Tue Jan 17 2012, 12:00PM
Ahhh yes that explanation clears things up!
I now the significance of USDMH, and the red-fuming nitric acid, but the other stuff i did not.
i will read that book, id also like to find "no guts, no glory" by Frederick boots blesse, but cant find it...
Im reading John D. Clark's work now!
"Peroxide-Always a bridesmaid " ...LOL! does sound about right though.
Wed Jan 18 2012, 01:28AM
Yup. Don't overlook the system benefit of a hypergolic combination, esp. for an engine that has to be started more than once per flight.
Ever wonder why Space Shuttle astronauts didn't open the hatch right after landing?
Among other things, ground crew had to verify that the OMS system wasn't leaking any N2O4 or monomethyl hydrazine.
Wed Jan 18 2012, 02:25AM
yes kluge, the shuttles also putout alot of ammonia after landing.
