  • Guests: 36
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Making circuit boards by hand
Zum Beispiel
Mon Jan 16 2012, 11:18PM Print
Here's a little video I made about making PCBs at home. A permanent marker and a steady hand is all it takes. Just in case anyone is interested:
(Now complete with crappy pictures and editing, all in glorious 1080p!)
This method is great for making one-shot boards, but I wouldn't try it if the board has many ICs on it, or requires many fine traces for some other reason. For power boards, such as this inverter, with fat traces it's fine, though.
Comments?
Tetris
Tue Jan 17 2012, 01:16AM
I find the "if there are any girls" comment sexist. Because the poster renders that argument invalid :P but where do you get the boards?
Tue Jan 17 2012, 01:57AM
Have you tried the H2O2 + HCl etchant? its much less temperature sensitive then ferric or ammonioum...
i just think the oxygen ion count needs to be upped when it gets dark.... i was contemplating using and fish air pump with air stone for this purpose.
dingo27
Wed Jan 18 2012, 08:10AM
dingo27 Registered Member #890 Joined: Tue Jul 10 2007, 10:06PM
For me pernament markers have unpredictable results.
I use email paint markers like edding 750 and 780, they need to dry for 5 minutes, but there is no way the acid gets through them.
Wed Jan 18 2012, 09:11AM
I use sharpie paint markers, have always had good results, the felt tipink markers can lead to "pinhole-ing".
GluD
Wed Jan 18 2012, 01:32PM
GluD Registered Member #1221 Joined: Wed Jan 09 2008, 06:17PM
I have always used roughly the same method although I drill all the holes and then draw traces with a proper PCB marker, they was given to me for free a long time ago so I dont know if they are ridicously expensive, but I have never had problems with the ink being washed off. I use iron chloride to etch the boards and either grind the ink off with steelwool or use acetone.
Aperantly alot of people dont like the iron chloride ? I have never had problems with it.
Also would it not be better if the corners or edges, were 'rounded off' instead of so sharp turns? I dont really know much about PCB's so maybe I am wrong.
Wed Jan 18 2012, 02:52PM
GluD wrote ...
isnt iron chloride the same as ferric chloride?
Is it FeCl2 and FeCl3 ? i dont like ferrice chloride its dirty, and when it fills with sediment it becomes abbrasive to the ink.
Zum Beispiel
Wed Jan 18 2012, 08:55PM
HighVoltageChick wrote ...
Any shop that sells electronic components should have them.
Patrick wrote ...
Haven't tried that. I don't make boards that often and Perchlorate seems to do the job just fine for me.
I've personally never had any problems with this method. I just always use a marker with a bit 'thicker' ink and I've never had it etch through. Edges can be a bit of a problem if you're not careful, though.
Dr. Who
Wed Jan 18 2012, 11:22PM
Dr. Who Registered Member #326 Joined: Sat Mar 18 2006, 01:12PM
Nice video.
I use a permanent overhead projector marker pen for the etch resist (also handy for touching up gaps in press-n-peel boards), and ferric etchant. I know ferric chloride's messy, but I got a stack of it for free and I etch outdoors and wear old clothes.
Neet Studio
Sun Jan 22 2012, 05:15AM
Neet Studio Registered Member #4037 Joined: Fri Jul 29 2011, 03:13PM
I use toner transfer with glossy paper from junk mail catalogs for doing PCB at home.
In some parts of the board I can squeeze a bit finer lines at 0.007" to go between pads. I work mostly with SMT parts. My limits at the moment is 64 pins 0.5mm pitch TQFP which requires a lot of 0.01" lines with 0.01" spacing. Anything beyond that seems to be a bit messy to route or breakout without using lots of small vias.
As for etching, I use Ferric Chloride or Ammonium persulfate. Ferric Chloride is a bit faster, but messy. I place the PCB in a plastic container and place on a home made heating pad. The heating pad is about 20W resistors glued to back of a metal lip with a thermistor/comparator/MOSFET temperature control. Finally got myself a < $10 digital scale to mix the solution properly.
For double side board, I etch one side first while covering the other side with packaging tape. After etching, I drill a few holes and use map pins to align the print out for the other side. Iron it down and use a marker to touch up on the pads that have been drilled out. I also try to touch up the pads on those holes on the other side in case the liquid leak through.
Sometimes I do the side with more details first as I can reuse the solution for the other side.
1327209073 4037 FT132479 Tusb3210
It seems like I am having more trouble with the thicker tracks than the fine tracks. ;) Board is solder plated with hot soldering iron.
