  • Guests: 34
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Can I substitute EL34 with 6L6?
hsieh
Wed Jan 11 2012, 03:05PM Print
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
If I want use 6L6 in this amp instead of EL34,should I change anything?
1322841555 1412 FT0 P1000156
I want to use 6L6 because original British EL34 is very hard to find and expensive and I don't want to use Chinese EL34. I can find metal shell RCA 6L6 at much lower price.Can I use them in this amp?
Will this modification reduce or increase distortion of this amp?
Thanks
Wed Jan 11 2012, 04:50PM
Be careful with the metal shell 6L6s. They have lower voltage and current ratings than the EL34. You want the glass envelope 6L6GC, which is considerably higher rated.
You may need to adjust the cathode resistors, R107, 108, 207, 208.
The Russian 6P3S-E is similar to a 6L6GC and is cheap and robust. Not sure of its sound quality in a hi-fi amp, but it works well in guitar amps.
Japanese Matsushita 6CA7 tubes were very similar to Mullard EL34s. Link2 I ran my hi-fi amp with a pair of Matsushitas in one channel and a pair of Mullards in the other, and it sounded pretty fine! smile Maybe you can find some cheaply in Taiwan?
I refuse to pay the crazy prices, but since I live in Britain, I can sometimes salvage tubes from ancient lab equipment.
