  • Guests: 74
RoV IW3IPD (63)
01/13 si2030 (62)
High voltage neon transformer Fart opinion needed...
ifryd
Tue Jan 10 2012, 05:05PM Print
ifryd Registered Member #4215 Joined: Wed Nov 16 2011, 09:45PM
Hi friends...
I have opportunity to buy neon transformer 10kV/ 100mA. (4,88A 230Volts) It is FART transformer dedicated to neon lightening. My questions are:
1) Would you recommend buying this transformer?
2) Does this transformer keep its parameters? I mean does it really give 100mA.
3) If it gives 100mA /10kV why manufacturer writes 422W, shouldn`t be 1000W at least?
Also parameters (4,88A 230Volts) suggest power should be above 1kV.
4) What is dedication of 50nF capacitor to neon transformer? protective? lowering current?
Yours,
Inducktion
Tue Jan 10 2012, 05:21PM
We need more information about the transformer...a datasheet, or at least a picture of the specifications label would help a lot....
A 50 nF capacitor would probably be to help with PFC, *I think*...
And, I'm sorry, but the thread title made me giggle out loud.
ifryd
Tue Jan 10 2012, 05:30PM
Haha I was not aware of it when I was typing... :) But lets leave it for a while to make other people laugh...
jpsmith123
Tue Jan 10 2012, 05:48PM
Neon Sign Transformers have a built-in ballast; they have a magnetic shunt which acts as an inductive reactance. The 100 ma spec is a short circuit current and the 10 kv spec is an open circuit voltage. Depending on the load, you'll get something in between.
ifryd
Tue Jan 10 2012, 06:02PM
Ok I understand but if you had to choose between Oil Burner Ignition Transformers (let say parallel connected) and high voltage neon transformer what would you choose? I am interested in charging capacitors and then discharge them. Sort of tesla coil application...
Neon transformer weights 17kg.
jpsmith123
Tue Jan 10 2012, 06:23PM
I'd have to have more information about the intended use before I could recommend anything. If it's just for foolin' around, I'd say go for whatever's the best deal.
ifryd
Tue Jan 10 2012, 06:49PM
I would like to charge capacitor (16kV 0.05uF) and then discharge it with the frequency of about 250Hz. In each cycle of discharge capacitor will be fully discharged...
Basing on the above which option would be best for me... (It is really hard to get reliable source of high voltage on market). I will add I want to fully charge capacitor to 10kV. Accumulation of Charge can be less than allows capacitor but I would like to achieve full voltage potential available from the transformer.
With regards...
Tue Jan 10 2012, 08:31PM
10kV open circuit, 100mA short circuit. So maximum power output is at something like 5kV, 50mA.
Excellent for powering a Tesla coil. The figure above is for a resistive load: a capacitive load partly cancels the ballast inductance and gives more power than you expect.
jpsmith123
Tue Jan 10 2012, 08:36PM
Given those numbers, your transformer will have to supply: P = 250*[0.5*(10000^2)*(0.05exp-6)] = 625 watts of power.
Probably you'll have to put two or more neon sign transformers in parallel to get that kind of power throughput.
Platinum
Tue Jan 10 2012, 08:38PM
I'd get it if I could, NST's are very good HV power supplies, and are very good and stable.
