  • Guests: 33
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
What is maximum gate voltage for this scr?
dingo27
Sun Jan 08 2012, 10:40PM Print
dingo27 Registered Member #890 Joined: Tue Jul 10 2007, 10:06PM
I have troubles understanding this datasheet
what is a maximum gate voltage? It seems 4 volts, but i think its quite low...
i was expecting maximum gate voltage column, but there is only "Maximum required DC gate
voltage to trigger" ,
thanks in advance
Pinky's Brain
Sun Jan 08 2012, 11:03PM
It just means that if your gate voltage reaches 4 volt it is sure to trigger (at -40 celsius, 2.5 volt at room temperature).
The maximum allowable gate voltage is power limited, depends on pulse width and has to be derived from figure 8, which I have no idea how to read.
Mon Jan 09 2012, 02:12AM
let me look may be ill remember the 90's...
to me it looks like youll need:
2.5 V, at 300-700mA to fully trigger a power pulse into a resistive load.
with the caveats that:
never let the gate drop below -10 volts, or the gate will die.
or exceed its average power/heat capacity for your waveform. thats in fig 8.
remember these SCR's are current contrlled devices, not Voltage controlled, like IGBT's or FET's.
if you include a reisistor in series with the transformers secondary (lets say 5 volts.) , the gate voltage needed will appear across the gate, with the balance across the low ohm resistor. like a zener or led circuit. these have more difficult drive condidtions then voltage controlled switches.
there was a masterful example of a scr tesla coil using a saturable inductor, in the late 90's, but i cant remember the website or name of the person. EDIT! it was Alan Sharp, but wayback doesnt have any of his work on SCRs.
teravolt
Mon Jan 09 2012, 03:18AM
2.5v@150mA at 25 deg C
Mon Jan 09 2012, 03:45AM
teravolt wrote ...
but he needs to realise thats the lowest drive for a weak current voltage switch, with a T0-247 i assume he means to really push some power, which means he needs to drive the gate real hard.
Mon Jan 09 2012, 10:08AM
A SCR is a current-controlled device, much like a bipolar transistor. The gate turn-on voltage is usually somewhere around 0.7 volts, but may be higher. The trigger circuit must be able to set the gate trigger current to the required value through the trigger voltage range. Triggering a SCR from a low-impedance voltage source may damage it.
Mon Jan 09 2012, 10:10AM
SCR gates are current operated, like a transistor base. The way to drive them is a 12V pulse through a resistor sized to give the required gate current.
Eg, if the datasheet says the SCR needs 100mA worst-case, and the gate voltage is 4V worst case, then the resistor is (12-4)/0.1 = 80 ohms.
A 100 ohm resistor between gate and cathode also helps to avoid spurious triggering in dimmer and inverter type circuits.
Mon Jan 09 2012, 10:17AM
In really fast switch, high current pulses, they can kick back out of the gate too, so others ive seen use a transformer to drive the gate power.
dingo27
Tue Jan 10 2012, 12:19PM
I will use it doubled in coilgun, so i need to push it to limit.
With previous scr (2x bt152-800R) i switched gate with 5V and no resistor (2200uF discharged into gate through p mosfet), but i destroyed it with dry shot mistrust so i ordered 2 of those (with this Link2 ) and i am waiting for better results
i'm not new to electronics, but current driven devices are harder for me to understand than mosfets.
for start i will try those 4 volts and post some result and photos in electromagnetic accelerator page.
If anyone has more useful info, let me know
Thank you all one more time.
Tue Jan 10 2012, 08:14PM
dingo27 wrote ...
This statement makes me suspicious...
