  • Guests: 34
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
HV insulator.
Platinum
Sat Jan 07 2012, 04:20AM Print
I *cough* found *cough* a HV insulator, the type you get on pylons, what I want to ask is, wth does it do, I put a flyback on the two outs and it looked like a capacitor was charging?
Pic
Sat Jan 07 2012, 07:45AM
It looks like a plain insulator of the kind found on 25kV railway overhead wires. It is just a solid lump of high-grade ceramic and it doesn't do anything exciting, its purpose is simply to give mechanical support without conducting electricity.
Sat Jan 07 2012, 07:50AM
nice rescue form the garbage dump i presume, I agree with Connor, there nice to have to hold stuff up. You shoudnt really see any behavior from it, so im not sure what your question is...
we cant see the ends, so it could be an insulator or a pass-through bushing for a component case. can you ohm out the two ends and re-post pics?
Platinum
Sat Jan 07 2012, 09:43AM
The ends are just threads where bolts go into, I unscrewed the bolts off it.
I got it from near a factory dump.
Pinky's Brain
Sat Jan 07 2012, 02:33PM
Isn't it just a high voltage feedthrough?
radiotech
Sat Jan 07 2012, 08:40PM
If it is rigid, it would be a bus bar support from a substation.
One thing about old substations. Sometimes they appear abandoned and have
a lot of vegetation growing. But they may still be energized , even though
the factory or plant has been shut down for a long time.
1325968828 2463 FT131707 Swichyard
