  • Guests: 36
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
HV insulation thoughts... Mylar, Polyester resin and alkali's...
Fri Jan 06 2012, 07:22AM Print
a thought occurs, i maybe wrong so everybody check my logic and reasoning on this one....
mylar film (BoPET, which is a form of highly organized polyester.) is chemically resistant to most chemistry, with the exception of Alkali's.
what if i were to take mylar films, soften the outer surface with sodium hydroxide then stack them for many kV's of thickness, with the layers saturated in polyester liquid resin/catalyst?
would they merely peel apart when fully cured?
if a 0.0045" thick sheet could hold off 3.8kV x 4.5 = 17.1 kV, then 7 layers would break down at 120 kV.
if true, then 0.038" would definatly hold 40kV form long a duration.
Is this a good idea? or am i just out-smarting my self again?
mylar pdf's
]electrical_properties_mylar.pdf[/file]
]chemical_properties_mylar.pdf[/file]
Fulmen
Fri Jan 06 2012, 09:11AM
Fulmen Registered Member #3883 Joined: Fri May 13 2011, 06:30PM
It can be done. I recently made a few credit card-style caps from aluminum foil and hot-laminating pouches. I used a combination of the hot-glue on the pouches and epoxy, and while they could be pulled apart with force they didn't peel apart by accident.
Most of them failed pretty fast, but a few seems to work quite well. I would recommend a vacuum pump and a press to get a tight air-free stack.
Fri Jan 06 2012, 11:16AM
im trying to get insulation for my HV planar transformers. so id like to avoid any peeling at all.
Fulmen
Fri Jan 06 2012, 11:46AM
It shouldn't peel with normal handling, but if you try to pull the layers apart they will separate. Takes a bit of force though, they don't just fall apart.
Fri Jan 06 2012, 08:06PM
I think you're outsmarting yourself because given the available space
I'd expect surface tracking to be more of a problem than dielectric strength.
Afterthought; assuming that this is for >= 10's kHz
very high voltage between winding layers at high frequency will require a low loss dielectric I think.
I'd guess around
(number of layers) x (inter-layer capacitance) x (Vrms per layer)squared x 2.pi.F x DF
Watts would be dissipated in the dielectric.
DF for Mylar is around 1% I think. (DF=0,01)
(probably a better approximation should be available)
Fri Jan 06 2012, 08:59PM
im aiming for 100kHz and mylar DF is about 0.01~.012 .... for that freq. howerver my pie winding will be held together with epoxy, with an unkown DF ill
2Spoons
Sat Jan 07 2012, 11:18PM
hitting mylar (PET) with an alkali will depolymerise it into terephthalic acid and ethylene glycol. This is not the same as solvent softening of a plastic, where the intact polymer partly absorbs some solvent.
Sat Jan 07 2012, 11:25PM
2Spoons wrote ...
yes i realise that, and thats what i wanted but it didtnt work with or without the NaOH.
Fulmen
Sat Jan 07 2012, 11:29PM
I did it without NaOH, but I used epoxy which is a far better glue than polyester. Find a thin epoxy made for laminating purposes before you give up.
Sun Jan 08 2012, 03:09AM
Fulmen wrote ...
yes my current experiments show epoxy to be suppior
