  • Guests: 20
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
has anybody ever made a tesla tuner out of a seeing eye tube
teravolt
Sat Dec 31 2011, 04:29AM Print
I am looking for ideas. alot of old radios used to use thease tubes in old radios. I basicly know how to use thease tubes so I'm kooking to see if any body has tried this. I sapose one could use a sweep generator and a detector diode and a op-amp to drive it
Sat Dec 31 2011, 10:42AM
In uk we call them 'magic eye' tubes
and they are just a non-linear un-calibrated voltmeter
so anything (that can be converted to a voltage) can be 'tuned'
e.g. error signal in a pll, grid-dip type meter,
I think a sweep generator / ac signal could be fed directly to the eye tube
but a detector would give a brighter steadier display.
teravolt
Sat Dec 31 2011, 06:40PM
typicaly I use a pulse generator and o-scope wich probibly tell me what I would want to know but it would be nice to have something portible and magic eye tubes have a cool look. I would like to be able to sweep a tesla fully built and see the upper pole and lower pole or resonant peak. I might add a frequency counter so I mark the frequencys. thanks for the help.
radiotech
Sat Dec 31 2011, 06:53PM
A far more productive alternate use of an (magic eye ) electron ray indicator
is an experiment to determine the mass of an electron.
If you place the eye tube into a solenoid, there is a relationship between the
magnetic field and the swirl radius of the distortion.
So, with your thinking cap on, and knowing this value 1.5924(17)×10−19 C,.....
teravolt
Mon Jan 02 2012, 07:06AM
thanks radiotech, I found this website and a couple others
that I'm looking for. I started this thread to find some good things to measure in a Tesla. right now I am working on a CM300 DRSSTC and I'd like to see things like frequency drift or primary current when a spark is being generated. I just think they look cool and would make a good visual addition. when I get a chance to do this project I will revive this thread when I find out to measure and implement.
radiotech
Tue Jan 03 2012, 12:26AM
All the "usual" on the net is rehash of what those tubes did in the past.
This experiment, although about 50 years old, can be used with minimum
apparatus to consider some science.
We had fun doing this. Less fun doing the math. No calculators. amazed
1325550376 2463 FT131243 Magiceyephysics
teravolt
Tue Jan 03 2012, 04:19AM
thanks for scanining it for me I'll take a look at it
Tue Jan 03 2012, 08:52PM
Have a salvaged tube here as well as a presumably working "flat" CRT, anyone have a use?
-A
