  • Guests: 46
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Need help, resistor colors....
Thu Dec 29 2011, 06:51AM Print
i have desoldered many of these wire wound resistors.
ive searched for 5-band color code... but cant find this value...
black --- white --- silver --- gold --- black
1325141461 2431 FT0 Sam 0830
my ohm meter wobbles between 0.1 and 0.2 ohms, but i dont know if thats accurate.
Dr. Slack
Thu Dec 29 2011, 11:54AM
I can't help you with the resistor colours (I think either gold or silver could mean something like x0.1 or x0.01 the other bands, but I've not seen both together), but can suggest a better method of measurement.
If you have a known current source, or a stable one you can measure, then pass a current through the resistor, and measure the voltage *at the resistor wires with seperate terminals*. This is known as a 4-wire measurement, it avoids adding in the contact and lead resistance of a normal 2-wire measurement. It also allows you to use higher currents and lower voltage ranges than your meter might use by default on its minimum ohm range.
volt+     current+        current-        volt -
Fulmen
Thu Dec 29 2011, 12:57PM
Fulmen Registered Member #3883 Joined: Fri May 13 2011, 06:30PM
Weird. If you ignore the last band (black is not a valid tolerance value) you get 0.09ohm ±5% (silver is x0,01).
The extra black band could be temperature coefficient. but I'm only guessing.
Bjørn
Thu Dec 29 2011, 01:06PM
Black is 0 and it make no sense starting with 0 so what if we ignore the black bands and get 9 * 0.01 = 0.09 Ohm and 5% accuracy. Or 0.08 Ohm if it is a grey and not white band. Seems best to just measure it.
The 4-wire measurement is great for such uses but be careful with large inductors, even if you keep the voltage low you can hurt yourself if you disconnect the current abruptly.
Edit: Fulmen got there first, black is 200 ppm/K.
Tetris
Thu Dec 29 2011, 05:48PM
But isn't resistance futile if <0.7 ohms?
Thu Dec 29 2011, 08:24PM
kelvin measurment on the way! ty all.
Thu Dec 29 2011, 08:49PM
Aside from the uncommon color sequence, the package shape is interesting.
I've never seen one that looked so much like a conformal coating over about three turns of thick wire.
We could estimate its inductance and corner frequency from the geometry.
When you're done with the four-wire resistance measurement, may I borrow the specimen to make an x-ray of it?
Or if your dentist has gone digital, ask him/her to please x-ray the resistor on your next visit.
Simpler yet (but less fun): since you said you have many such resistors, perhaps you can dissect one.
Thanks!
Thu Dec 29 2011, 08:53PM
klugesmith wrote ...
Thanks!
i need my own xray lab for this reason, ive PM'ed you... its actually two resistance wires wrapped in CW and then CCW...
radiotech
Thu Dec 29 2011, 08:58PM
Try this code. Characteristic.. frequently used to include various qualities.....
1325192282 2463 FT131122 Eiacode
Thu Dec 29 2011, 09:16PM
by radiotechs chart i get:
09 x 0.01 +/-5% characteistic A = 0.09 ohms +/- 5% Characteristic A
