  • Guests: 50
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
magnetron coupling.
cedric
Sat Dec 24 2011, 12:52PM Print
cedric Registered Member #2941 Joined: Fri Jun 25 2010, 08:08AM
hello everybody,
I want to couple a magnetron with a high voltage high power 75 ohm coax for some experiment, but I can not get any information about the output impedance of a standard magnetron. the 1/8 wave antenna of the devise suggest a low impedance source (but I am not sure), impedance transformer are not an easy think to build unless I have some idea of the output impedance of the magnetron itself, please can some one help me ?
ps:I am a high voltage ingenieur and I have some understanding about microwave energy ,so please, spare yourself the traditional warning paragraph .
Sat Dec 24 2011, 02:10PM
The antenna should be 1/4 wave not 1/8, as a 1/4 wave probe is a standard way of coupling to waveguide. The tip is a high impedance voltage node, which is why it has the large metal end, to stop breakout. And being a 1/4 wave vertical, the impedance at the base ought to be about 50 ohms.
It could be done a number of ways, but if it were me, I'd attach another 1/4 wave line to the tip of the antenna to extend it to 1/2 wave. This will transform the impedance back to what it was at the magnetron. Then attach a coax connector (N type?) to the end. Enclose the resulting line in a copper shield that attaches to the magnetron body at one end, and the outer part of the coax connector at the other. Make sure the connection is really good, the shield is a good Faraday cage, and there is a decent amount of clearance around the line. (ideally the shield is a tube of a size that would be 75 ohm coaxial with the diameter of the antenna tip)
You could also add a tuning screw that allows you to vary capacitance to ground around the 1/4 wave node.
Disclaimer: never tried it. Seen others do it a different way, using a short piece of rectangular waveguide with another 1/4 wave probe in the other end.
cedric
Sat Dec 24 2011, 02:41PM
thanks for the answer,
I realize my mistake about 1/8 antenna,
I didn't consider the ceramic part of it witch of course radiate as well, now the funny thing is that with the ceramic part the antenna is 25.75 mm long, witch is not exactly 4/1 wave , but maybe they use trick to tune it with the internal feed line...50 ohm to 75 ohm is (sort of) of acceptable to me as I don't intend to run the magnetron at full power.
Mon Dec 26 2011, 10:06AM
Have you seen the microwave ion source on coultersmithing.com?
Tue Dec 27 2011, 10:51PM
Oh, sorry for the double post but I wanted to post this link before I forgot. It shows an actual magnetron to N connector job.
cedric
Sat Dec 31 2011, 03:35PM
Dr. Watt The Fork wrote ...
I have seen it , but what is the benefice of coupling it this way?
Sat Dec 31 2011, 03:41PM
It's the easiest way to understand, as it's just the magnetron antenna in reverse.
Doug Coulter's ion source shows the technique I tried to explain. I think you can just put a coax connector on the end of the hardline where his resonant cavity is.
hboy007
Sat Dec 31 2011, 05:58PM
Link2 might be interesting for you. The link above shows the coupling of an antenna to a rectangular waveguide / cavity. I would also consider the stud coming out of the magnetron as an antenna, the cylinder shape effectively shortens the geometric antenna length and surpresses arcing.
You would start calculating the geometry based on the cut-off frequency of the most suitable cavity mode, then place the magnetron and coupling antenna at the electric field extrema.You could then also make one wall movable to adjust the power output.
Literature suggestion: J.D. Jackson, classical electrodynamics (a very thorough introduction).
