  • Guests: 59
RoV IW3IPD (63)
01/13 si2030 (62)
ZVS driver
Platinum
Sat Dec 24 2011, 12:22AM Print
A member here made me a ZVS driver, we had some arguments but I'm sending the money tomorrow, , so I want to knwo what is the maximum input power I can use?
What is the max voltage and current?
Is there anything that can make this driver blow up, low amount of turns? or is it designed to be short circuited?
Sat Dec 24 2011, 12:33AM
you have to post schematic, part numbers and certain known values for us to say anything useful.
But, in short, yes you can do many things to kill our drivers.
Platinum
Sat Dec 24 2011, 12:48AM
It is based on IRFP250 I think.
Sat Dec 24 2011, 01:15AM
ZVS's are one ofthe few things related to HV ive only some experiecne with, so ill adviseyou on what i can. but we need more info than that.
Hae you looked at the datasheet for that transistor?
Platinum
Sat Dec 24 2011, 01:24AM
200v 33A
Most people say max input voltage is around 36v's? and max current I'm not sure.
Sat Dec 24 2011, 02:58AM
here:
]irfp250.pdf[/file]
I think your limited to 18 amps or less sloshing around through those transistors.
Platinum
Sat Dec 24 2011, 05:23AM
Can the ZVS directly drive a tesla coil?
I've built a 20W SGTC, not powerful lol but it worked.
Marko
Sat Dec 24 2011, 01:04PM
Well, to tell the truth, the mazzili inherently isn't a very reliable driver as it suffers from latch-up condition if it becomes unhappy for any reason, and that's why I wouldn't sell you one that doesn't have overcurrent protection included and carefully tested!
If you're driving it from a bunch of lead acid batteries or whatever similar powerful source people seem to usually use, mosfets will blow in an instant this happens.
It seems that the circuit works best if you don't deviate from original mazzili form, and not exceed the ~40V input voltage he stated. (Although the mosfets could go with 60-70)
IIRC, the original mazzili's idea was to drive a tesla coil with this, offline. I don't recall to which extent it succeeded, though. I smell lots of blown igbt's and mosfets.
Marko
Sat Dec 24 2011, 01:47PM
The person you bought it from should be able to tell you the max voltage and current he designed it for. If he can't, he's a noob tongue
Platinum
Sat Dec 24 2011, 02:43PM
I was going to run it of a 20v 3.25a laptop battery (18650) charger.
