  • Guests: 64
RoV IW3IPD (63)
01/13 si2030 (62)
ZVS Insulation problems
frylock1315
Mon Dec 19 2011, 02:38PM Print
frylock1315 Registered Member #4275 Joined: Mon Dec 19 2011, 01:55PM
Hi, i have a Mazilli ZVS driver driven off of a 25v 10A transformer with an old AC flyback transformer that has a black tar like substance over it for insulation the problem I am having is the secondary of the flyback arcs over in air and under mineral oil the insulation on the secondary is being eaten away by the oil. So i was hoping for an alternative to mineral oil and heat might be an issue as well.
Platinum
Mon Dec 19 2011, 06:12PM
Wax.
Inducktion
Mon Dec 19 2011, 07:06PM
Specifically, beeswax has been used and shown good insulation characteristics too.
Mon Dec 19 2011, 10:43PM
So, sre you all recommending that he use the mineral oil to remove the remaining tar-like stuff, then recover with beeswax?
frylock1315
Wed Dec 21 2011, 02:41AM
Thanks guys, I will try that and post pictures when I'm finished.
frylock1315
Sat Dec 24 2011, 08:55PM
Well I couldn't find beeswax so i put silicone caulking over the previous insulation and covered the flyback transformer in mineral oil and no arc overs now.
Sat Dec 24 2011, 11:15PM
you could also make a cup or tank that hold oil...
like i did, then you can skip the caulk....
1311927961 2431 FT120576 Psbox2
Uzzor2k has good info on his website too.
