  • Guests: 27
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
DC motor control with high frequency pwm
Fri Dec 23 2011, 05:27PM Print
Hi,
is there any problem with using say, 20 kHz drive frequency, for a single-switch step down controller running a dc permanent magnet motor directly (without any LC filter)? As I understand it, the hysteresis and eddy current losses shouldn't increase with frequency if the drive voltage isn't increased, is this right?
Fri Dec 23 2011, 05:32PM
Don't think there's a problem, that's how the controllers in cordless drills and RC cars work.
Harry
Fri Dec 23 2011, 06:18PM
Harry Registered Member #4081 Joined: Wed Aug 31 2011, 06:40PM
So can I run a flyback from the guts of a handheld drill?
Fri Dec 23 2011, 06:22PM
Ok thats great, thanks smile
Edit: Harry, this kind of controller isn't suitable for driving a transformer.
Fri Dec 23 2011, 06:27PM
Well, it might do something, but don't try it with your brand new DeWalt as the risk of blowing up the drill would be high! :/ There's also a freewheel diode across the motor that would have to be removed, as it would kill the flyback spikes. These are unwanted in a motor drive but kind of important for driving a flyback.
Most cordless drills I've used make an audible squeal, implying the frequency is nearer 2kHz than 20, so try an ignition coil instead smile
Harry
Fri Dec 23 2011, 06:34PM
Thanks, that's some great information. I'll keep trying to build a proper flyback circuit, I can never seem to get them right.
radiotech
Sat Dec 24 2011, 02:19AM
Hysteresis losses increase as frequency increases. Eddy current losses increase as the
square of the frequency in ironlike cores.
Sat Dec 24 2011, 04:36PM
I have seen a flyback run from a cordless drill but I don't think the drill lasted too long. The flyback had moderate performance.
Harry
Sat Dec 24 2011, 08:30PM
What about a ballast and something to stop the voltage spikes going into the controller?
