  • Guests: 69
IAmSpock (18)
01/30 Ian (37)
01/30 Lucas (40)
01/31 Mathias (42)
Fixing an old HP spectrum analyser
Fri Dec 23 2011, 03:52PM Print
To get the festive season off to a start, I decided to fix this beast. I was fed up of tripping over its partly dismantled carcass in the hall.
The main problem was that a lot of green resistors had gone high or open circuit. Most of them were in the log converter, which completely randomised the display. There was also a leaky electrolytic in the power supply's voltage reference, dragging all of the rails down.
The (analog) storage hadn't worked for so long that there was a vintage Dymo tape label on the control panel, saying "No Storage". Having never seen an analog storage CRT before, I was determined to fix that. It turned out that one of the connections to the CRT was bad.
All of the schematics and service manuals were found at the Boat Anchor Manuals Archive, bama.edebris.com.
Now all I need to do is find a use for it! smile The RF section has a range of 0-110MHz and that doesn't cover a lot nowadays. I am somewhat spoilt as I have access to a 9kHz-1.5GHz one at work.
1324655520 30 FT0 Spectrum3
The bad parts
1324655520 30 FT0 Spectrum2
Whee.
1324655520 30 FT0 Spectrum1
Part of the calibration procedure. Multiple traces are overlaid with the storage capability, trimpots are twiddled until the spacing between them is one division. (That wasn't quite done yet.)
teravolt
Fri Dec 23 2011, 08:29PM
can you use it to see the upper and lower poles of a tesla
Fri Dec 23 2011, 09:13PM
Yep, I'm pretty sure that would work. It also has an 0-11MHz range, I tried that with an audio signal generator, and it can resolve a 10kHz signal, so a Tesla coil should be doable.
I also got the 8443A tracking generator, so it might be possible to use that with the analyser to draw out the frequency response of a coil system, as long as it's above 100kHz. The generator won't go any lower even if the analyser does.
Fri Dec 23 2011, 10:12PM
what is that black rectangle labled "center freq" there for? does it have a needle that moves via knob or what?
Sat Dec 24 2011, 06:37AM
Yes, the centre frequency display is a tuning dial like an old-fashioned radio.
Paul Benham
Wed Feb 08 2012, 09:53PM
Paul Benham Registered Member #570 Joined: Wed Mar 07 2007, 03:41PM
Build a return loss bridge and you will have a scalar network analyser too with the tracking generator.
