  • Guests: 65
IAmSpock (18)
01/30 Ian (37)
01/30 Lucas (40)
01/31 Mathias (42)
New DRSSTC Build Bigger and Better
colin heath
Fri Dec 30 2011, 06:23PM Print
colin heath Registered Member #123 Joined: Fri Feb 10 2006, 12:58PM
Hi All,
Well it has been a while since doing any tesla coil building. I have started building a new coil now and will have following specs:
8" x 36" secondary
Flat Spiral Primary
Tank cap to be calculated.
Drive is a Steve Ward DRSSTC 1 board but will be modified to accept the Prediktor circuit Finn Hammer came up with. Bridge will be 4 CM600 running on GDT but this will be run from a remote H bridge to give current required.
Here is a pic of the interrupter which is just 555 timer but may become more advanced later for musical use.
1325269426 123 FT0 Drsstc Interupter
Paul Benham
Tue Feb 07 2012, 08:23PM
Paul Benham Registered Member #570 Joined: Wed Mar 07 2007, 03:41PM
Good luck Colin.
I started on mine last year but did not get very far. I'm up to 200W input power CW at the moment and still sorting the feedback circuit. I used Finn's predictor to start with and then went on from there.
Hope you get it all finished before I do!
Cheers,
Paul.
Tetris
Wed Feb 08 2012, 04:07PM
How big do you plan to make it?
colin heath
Wed Feb 08 2012, 05:14PM
Well things have ground to halt at present. I have stuffed the board all bar 2 resistors I think. Work is really busy and training courses etc also so no time at present.
I plan to make the coil pretty large maybe something along lines of biggest in UK if possible but need to get something working properly on had sensible scale first.
Wed Feb 08 2012, 10:32PM
colin heath wrote ...
With the amount of power you can push through a CM600 bridge, you should seriously consider a longer secondary, like atleast 150% of your original plan.
What fun is it to have a 1,8 meter tesla coil that can make 3-4 meter sparks, you will have to elevate the complete system to avoid constant groundsparks at much reduced length compared to what its capable of.
colin heath
Thu Feb 09 2012, 07:17AM
You are probably right on that point and to be honest nothing is set in stone at present so welcome any input or critique of design.
This may take years to finish but am going to concentrate on the electronics first as the rest of it is just fabrication and no problem whatsoever :)
