  • Guests: 22
GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
Making a PSU?
Platinum
Mon Dec 19 2011, 06:48AM Print
I want to make a 12v psu from a toroidal core, quite small (rated around 200W) I think it's iron powder but it came from a 15khz PSU. What do I need to do firstly to the core, then I have a 6A single phase rectifier, and some caps, only thing I'm confused with is the ratios, do I wind 240 turns and then 20 odd turn and regulate to 12v?
Thanks.
Experimentonomen
Mon Dec 19 2011, 10:46AM
This toroid is from a switchmode power supply and can NOT be used with 60Hz mains frequency!
If you want a regulated 12V psu, get a 12-15VAC iron core transformer, a bridge rectifier, a LM7812 and some capacitors.
genious 7
Tue Dec 20 2011, 04:09AM
genious 7 Registered Member #2887 Joined: Sat May 29 2010, 11:10PM
Bear in mind that the LM7812 will be good to an amp or so on the base design. For the cost of a beefier output stage, I recommend you to buy an ATX computer PSU (the cheapest one you find) and use it as a power source. They give +3.3, +5, and +12v and are short circuit proof.
Or, take the hard route and get a 12v transformer, rectify it, filter capacitor, and several LM7812 with current sharing resistors, just as if one were sharing current among multiple bipolar transistors.
Inducktion
Tue Dec 20 2011, 04:30AM
Or you could screw all that, get a 30 volt transformer, an LM317, and a nice sized bypass transistor and simplify your design; Not to mention variable output.
Tue Dec 20 2011, 04:37AM
Platinum can you post pics of this toriod? is it yellow and white?
Platinum
Thu Dec 22 2011, 12:22AM
It's HF, so it is ferrite and will not work, may aswell buy another PSU.
