  • Guests: 50
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
red Laser from DVD burner, and making a pointer with it
Inducktion
Tue Dec 13 2011, 10:30PM Print
I took apart a DVD burner from a laptop recently, and I got a nice red laser diode from it. Knowing I can make a really nice laser out of it, I decided to keep it, and use it.
My problems were finding a lens, and I found one from a cat toy laser pointer we had that had a broken switch. The lens are actually glass, so they won't burn from the intense red light!
I make a CC driver for it, using an LM317 and 7.5 ohms of resistance on it, and anywhere from 9 volts input to around 4 volts makes the laser light up different brightness, nine being painfully bright, and 4 a little brighter than an average laser pointer. Is my CC source not working properly?
I also need to make a heatsink for it, since currently it's just got a bit of aluminum stuck to the case from the sled it came from. Any ideas how to make a nice heatsink for it?
EDIT:
I got the case out of the sled, and it's one of those open air ones.
Forty
Thu Dec 15 2011, 02:22AM
when you say painfully bright, you don't mean that you're looking at the beam do you?
Inducktion
Thu Dec 15 2011, 03:01AM
No. I'm not that stupid. :P
Shrad
Fri Dec 16 2011, 10:30AM
the LM317 current source behaves not really well with laser diodes
the best is to use an op-amp with an output transistor, a current measurement resistor, a feedback on the current value, and a pot at the positive input for current set
in this document Link2 the laser diode driver 2 is the best option
Wolfram
Fri Dec 16 2011, 11:08AM
Your results sound reasonable. The LM317 has a typical dropout voltage of 1.8V or so. The voltage drop across the current setting resistor is 1.25V and the voltage drop across the laser diode is probably at least 2V, so I'm not surprised that it doesn't behave as a very good current source when fed with 4V. Your supply needs to supply at least 3V more than the voltage across the laser diode for proper operation, maybe even more.
