  • Guests: 33
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Making a VGA projector with an old LCD screen...
Inducktion
Sat Dec 10 2011, 07:51PM Print
I tore apart an old LCD monitor some time ago, and was wondering if it would be possible to make a projector using the board?
Problem is, though, I only kept the board directly attached to the LCD, and here's the single cable that comes out of it;
Is this a lost cause trying to make a VGA cable with this, or even trying to make a projector?
Thanks!
Experimentonomen
Sat Dec 10 2011, 07:53PM
Forget about it!! Your much better of just buying a used lcd or dlp projector.
testtest
Sat Dec 10 2011, 10:27PM
testtest Registered Member #3271 Joined: Mon Oct 04 2010, 02:29AM
This might give you some ideas!
Turkey9
Sat Dec 10 2011, 10:58PM
I don't know exactly what all the connections are, but a lot of monitor screens are controlled via SPI by a microcontroller that interprets the incoming VGA signal. In short, without the controller board, it's not possible for the average hobiest.
Carbon_Rod
Sat Dec 10 2011, 11:59PM
That is likely an LVDS cable, and they are usually a manufacturer specific implementation of the protocol.... Could be a fun fpga and dual ported vram project... wink
Or...
An LED based Pico Projector is less than $100 on ebay, and some even have direct iPhone interface cables.
Cheers,
Sun Dec 11 2011, 03:24AM
Are both pics the same in the first post?
Inducktion
Sun Dec 11 2011, 03:59AM
Um, I guess they are! That would be a mistake on my part. :P
Shrad
Tue Dec 13 2011, 10:45AM
there are cheap direct VGA to LVDS converters on ebay from an unique chinese seller (no other seller has them)
I had a look to get some small 5"7 touch panel controllers, but they don't have a firmware for my TFT, but they have great controllers for LG, toshiba, dell and other TFT panels up to 13xx resolution, with audio in, tuner in, dvi in/out, etc...
not too hard to find, sorry I have no URL as I'm at work right now
