  • Guests: 34
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Understanding a Joule Thief
H8erade
Sat Dec 10 2011, 12:54AM Print
H8erade Registered Member #3451 Joined: Sun Nov 28 2010, 11:13PM
Hi, everyone.
I found this schematic of an efficient joule thief online:
Elec JT1
I grabbed all the parts and prototyped the circuit on my solderless breadboard; LEDs do light up, and my multimeter measures 3 volts. However, when I pulled the transistor out, the reading didn't change. I glanced at the circuit again and realized that the LEDs were simply connected to the battery terminals, albeit with the 10T coil's resistance. The transistor is essentially useless because it's not even being turned on! My other 2N4401s show no difference.
I get the feeling that I'm doing something painfully wrong. Have I misinterpreted the schematic?
Marko
Sat Dec 10 2011, 02:09AM
Hi,
Well the circuit is a boost converter, hence it can't reduce the voltage if you run it from 3V, and might likely blow either the led's or the transistor if you do. LED's would be ran from voltage source which is very bad for them, and the transistor is biased pretty hard to supply voltage so if oscillation stops it will act as a short.
Try running it from 1.5V and see the difference :)
Marko
Experimentonomen
Sat Dec 10 2011, 02:09PM
The whole idea behind the joule thief is to suck that last bit of energy out of half dead cells which electronic devices think are completely empty, hence the name "joule thief"
These devices are said to kep a LED lit down to 0.8 or even 0.5V.
Pinky's Brain
Sat Dec 10 2011, 03:21PM
What is the 100 ohm resistor to the second capacitor for BTW?
H8erade
Sun Dec 11 2011, 05:09PM
Dr. Pork: After I replaced the transistor and ran it from 1.5V, it seemed to work! It's been going strong.
Experimentonomen: Thanks, but I already knew the general idea.
Pinky's Brain: I'm not exactly sure.
Sun Dec 11 2011, 07:33PM
Pinky: It's to limit the average base current to the transistor. (the 47 ohm one limits the peak current)
Experimentonomen
Mon Dec 12 2011, 06:11AM
And to bias the transistor to encourage the circuit to start oscillating. Its essentially a basic blocking oscillator.
Inducktion
Mon Dec 12 2011, 03:43PM
Yes, it's basically a mini-2n3055 flyback driver, just with some different components.
