  • Guests: 60
01/13 si2030 (62)
Coil design
HVGuyAFSL
Fri Dec 09 2011, 10:57AM Print
HVGuyAFSL Registered Member #4252 Joined: Fri Dec 09 2011, 10:43AM
Hello guys. Im new over here and i'd like to know a bit more about coils and how to design its parameters.
I am trying to build a circuit for charging a capacitor and then discharge its energy through a coil. The high voltage is 8 kV. What is the minimum section of the wire between the capacitor and the coil and also the coil wire (for them not to brake while discharging)? How could i calculate it? I have searched but, since this is an LCR circuit, when the capacitor is charged and i close the discharged loop, the current is not DC, neither common AC. Its a transient (sinusoidal) with a high peak and this sine wave is attenuated ... This way i dont know how to choose the rated current in order to select the wire...
Fri Dec 09 2011, 11:05AM
Use a circuit simulator like LTSpice to calculate the RMS current.
Or for a Tesla coil type circuit, I use the following approximation:
Irms = (0.5* Ipeak* sqrt(Discharge time * number of discharges per second))
The RMS current figure can then be used to size the wire.
Bjørn
Fri Dec 09 2011, 11:11AM
The rated current for a wire is for a permanent current, it will take a lot higher pulsed current without any problems.
As a crude approximation a single discharge through a simple coil will be extremely lossy. That means that the wire will absorb the energy and convert it to heat. Find the energy contained in your capacitor, then calculate how much copper you need to get a reasonable maximum temperature for your application. Then you know the least amount of copper you can use.
Then figure out what wire to use depending on other requirements, like frequency of oscillation or maximum current.
HVGuyAFSL
Fri Dec 09 2011, 11:31AM
Steve: Thank you for the simulator idea. I have used this one in the past. Ill install it again. The formula has the number of dicharges per second but I i just want to discharge manually (like 30 per hour).
Bjorn: The energy i want to discharge is 2 kJ and the peak current it will generate when i close the loop is 35 kA. Which formula do i have for the temperature and consequently the section of copper i need for this application?
Fri Dec 09 2011, 11:44AM
For a single big discharge, you want to compute I2t (I-squared-t) which has the same relation to RMS current as energy does to power. The energy dumped in a resistor "R" is R*I2t.
Or, Bjorn's assumption that all the capacitor bank energy gets dumped as losses in the coil is a good, conservative one.
Then you need to know the resistivity and specific heat capacity of copper, and so on. Given an energy and a mass of copper, you can calculate the temperature rise, and set it less than what would melt the insulation on the wire.
At 35kA, Lorentz forces may also be an issue. They could tear a flimsy coil apart even if it stays cool.
HVGuyAFSL
Fri Dec 09 2011, 01:49PM
and where can i find a spice model for a switch? LTSpice doenst have one.
Fri Dec 09 2011, 01:51PM
It is called something like SW_tClose and is lurking in some folder somewhere.
Ash Small
Fri Dec 09 2011, 03:34PM
If you want to minimise losses you should choose the biggest diameter wire that will fit.
Fri Dec 09 2011, 09:04PM
Is'nt the Onderdonk fusing current case relevant here? at 0.1 second, 1 second and 10 second currents for copper straight wire.
HVGuyAFSL
Mon Dec 12 2011, 09:02AM
Patrick: Yes i think it is relevant. I just didnt know if it was the right formula to use. According to that equation, for t=400us and with Ipeak=35kA the minimum copper section is 2.4022 mm^2
