  • Guests: 43
ZVS capacitor charger
H8erade
Sun Dec 11 2011, 07:57PM Print
H8erade Registered Member #3451 Joined: Sun Nov 28 2010, 11:13PM
A few months ago, I whipped up a quick Mazzilli flyback driver, and it seemed to work fine (although I later disassembled it). Yesterday, I needed a high-current capacitor charger, so I tried replicating it. No output whatsoever - I even took the circuit apart and rebuilt it six times.
These are the parts I used (and am currently using):
x1 6V lantern battery
x2 IRF510 MOSFET
x2 1N4007
x2 1N4742A 12V Zener Diode
x2 470 ohm resistor
x2 10k ohm resistor
x1 1.0µF 250V 10% Metal-film Capacitor
x1 100 micro-henry inductor
The only difference is that I had a different battery brand last time, so if there is a problem, I suspect that's it. I'll get the same type of lantern battery and update my results, but I have a lot of doubts. Can any of you see another flaw that may be present with the above components?
Any help is much appreciated.
Marko
Sun Dec 11 2011, 08:16PM
hello,
First clue, "no output" as with or without load (capacitor) . While in "no output" state, does the circuit short out the power supply or draw little current at all? If it doesn't short the power supply, you wired it up wrong (let me guess - check how you placed your diodes)
You didn't say what kind of a transformer are you using. A PC power supply transformer in reverse, or what?
Your diodes could be replaced by faster ones, but those mosfets are also a very bad choice. If you insist on running from 6V you'd probably want to use something like motherboard mosfets or at least irfz44's.
Marko
H8erade
Thu Dec 15 2011, 08:23PM
Thanks for the reply, but I got it working. My wiring was incorrect, though it had nothing to do with the diodes.
I was using a 120v - 6v mains transformer (in reverse), which works surprisingly well.
PSCG
Thu Dec 15 2011, 08:34PM
PSCG Registered Member #3792 Joined: Sun Mar 27 2011, 06:07PM
Have you measured the output power? The transformer has a laminated core, right?
