  • Guests: 69
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
photo diode optical switch
ben5017
Wed Dec 07 2011, 10:08PM Print
ben5017 Registered Member #3315 Joined: Thu Oct 14 2010, 04:23PM
I am lookin for a circute diagram for the quickest firing, most reliable optical switch for a multi stage coilgun.
Pinkamena
Fri Dec 09 2011, 08:41AM
Pinkamena Registered Member #4237 Joined: Tue Nov 29 2011, 02:49PM
All kinds of semiconductor switches are pretty fast. You could use the design I proposed in this thread:
Depending on how much control you want of when to fire the coils, you could drop the second sensors. with a single sensor, the coil will fire just when the projectile enters it, and stop when it's in the middle. With two sensors, you can control how far away rfom the coil the projectile will be before it fires, but it will continue until the projectile is in the middle.
I'm sure there's simpler circuits out there that would fit you just fine, do a little googling :)
