  • Guests: 33
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
How to create a digital stopwatch?
Pinkamena
Mon Dec 05 2011, 05:56PM Print
Pinkamena Registered Member #4237 Joined: Tue Nov 29 2011, 02:49PM
Hi!
How can I build a digital stopwatch with a precision of at least a tenth of a millisecond? And is it possible to buy such a device pre-built?
Thanks.
Tue Dec 06 2011, 01:10PM
You just need a 'gate' that is opened and closed by the signal that you want to time;
an accurate clock/oscillator - for 1/10 ms resolution you need 100 kHz minimum;
and a digital counter to count the pulses that pass through the 'gate' whilst it's open.
or
buy something like this Link2 or Link2 etc.
Daedronus
Tue Dec 06 2011, 02:07PM
You can easily measure time intervals in the tens of ns range (probably even better if you use a few tricks) with a fpga.
Like this one:
Link2,400,790&Prod=BASYS2
Maybe it's overkill....depends on your budget and how fast you want results.
Pinkamena
Tue Dec 06 2011, 04:41PM
Thanks guys, this is just what I needed!
