  • Guests: 74
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
20W solid state variable resistance
Avi
Sat Dec 03 2011, 06:04AM Print
Looking for a relatively simple technique to make a solid state 20w adjustable resistance. The resistance of the device must be known at all times and not change when the current changes. Any ideas on how to do this?
If i use a mosfet or a BJT with a fixed gate voltage/base current, the main current conduction resistance seems to change depending on the current draw, so that method is out.
Note, there may be external resistances (of unknown value and possibly changing) within the circuit so determining the resistance by current alone will not work either.
I have thought about using 8 resistors of values of 1x 2x 4x 8x etc, and a relay across each one. but i am having trouble finding 8 power resistors of doubling value (i only need to about 200 ohms or so)
Note the supply voltage will only be 24v or less, 24v across 200 ohms is 2.9W so 20W is not required for all resistances but it may make design simpler
Pinky's Brain
Sat Dec 03 2011, 10:42AM
A sense resistor in series with the MOSFET and an opamp circuit which keeps the voltage across the MOSFET AND the resistor equal to some multiple of the voltage across the resistor? (Plus some filtering to make sure it doesn't become an oscillator.) The amplification of the opamp circuit determines the effective resistance of the whole.
Sat Dec 03 2011, 11:10AM
An op amp with its inverting input connected to a shunt in the source of the output MOSFET, and its non-inverting input connected to a resistor divider from drain. The output of the op amp goes to the gate, of course. Can use single supply if you use an op amp which has its common input voltage range from ground (eg. LM358)
Sat Dec 03 2011, 11:14AM
What Pinky's brain said. (edit-and dr kV) I've seen commercial "electronic loads" intended for testing power supplies, that offer constant voltage, constant current or constant resistance modes. The constant resistance mode works as described.
One issue is that the finite response time of the feedback circuit will make the "resistor" look like it has a little series inductance. And the MOSFET has a bit of capacitance too.
You can do the binary thing with 15 1 ohm resistors, just wire a single one, a string of 2, a string of 4 and a string of 8. If you want to continue, the next building block is a 15ohm with a 1 in series.
Pinky's Brain
Dr. Kilovolt : You're right ... I wasn't thinking straight, I was thinking the circuit would become slightly nonlinear if you just used a multiplication of the Rsense voltage for Vds.
So what you get is :
Vsystem = A*I*Rsense + I*Rsense => Rsystem = (A+1)*Rsense.
PS. still have to be careful about oscillation.
Sat Dec 03 2011, 11:21AM
Yep, you need a balance arrangement where the shunt voltage (negative) and the drain voltage (positive) are combined at one op-amp input. I guess the non-inverting one.
Pinky's Brain
Sat Dec 03 2011, 11:57AM
PS. if the discussion seems disjointed ... it's because of my unfortunate habit of editing straight after I post.
Sat Dec 03 2011, 11:58AM
Pinky's Brain: The circuit I described takes the total load voltage (transistor + shunt) and total load current (which is of course the same for the transistor and the shunt), so the V/I of the load should be constant.
Avi
Sun Dec 04 2011, 05:36PM
Pinky's Brain wrote ...
what? that sounds like a constant current regulator...
Dr. Kilovolt wrote ...
do you mean like this?
I would like digital input or analog voltage (3.3v max is possible without too much mess, 12v max with an op amp) input to control the resistance if possible
Steve McConner wrote ...
Speed and response time wont be an issue, doesn't need to be fast in my application.
Pinky's Brain
Sun Dec 04 2011, 06:07PM
When he says speed and response time he doesn't so much mean how fast it responds to changes in resistance ... he means in how fast it responds to changes in current, ie. how much like an ideal resistance it behaves.
For digital control you can use a digital potentiometer to handle the divider on the opamp's positive input ... that will also limit your bandwidth a bit though.
