  • Guests: 35
Goodchild (34)
pauleddy (34)
11/23 Munkey (32)
11/23 CokeCanNinja (31)
11/25 Chris (40)
Portable SACD Player! [NEW PIC]
FastMHz
Fri Feb 17 2006, 07:59PM Print
FastMHz Registered Member #179 Joined: Thu Feb 16 2006, 02:08AM
Location: Hagerstown, Maryland - Close to Prime Outlets
I'm a self confessed audiophile and love my SACDs and DVD-Audios...except a portable player doesn't exist to play SACDs, not even a car unit. So I'm going to build one. I won a universal SACD/DVD player on ebay and will make it lithium polymer powered. The trick was fitting an inverter, amplifier and batteries into the chassis.
FastMHz
Wed Feb 22 2006, 02:45AM
I started with a Pioneer 578. I intended to use voltage regulators to run the unit, until I started measuring the voltages on the power supply and found, amongs others, 3.3v, 4v, 6v, 22v and 27v!! Thus I ended up using a small inverter for now, to take the 12v battery power and feed it into the existing power supply. It has a runtime of about 4 hours. My next steps include painting it and working out an audio noise problem - turns out it's searching for ground and a 60hz hum can be heard when the volume is cranked.
1140576341 179 FT1296 Portablesacd
