  • Guests: 35
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
Cryomilling wax/thermoplastic
AndrewM
Tue Nov 29 2011, 10:49PM Print
I need to powder some thermoplastics and wax-type materials (for example, microcrystaline wax, polycaprolactone aka "Shapelock", polylactic acid, etc you get the idea).
The smallest wax powder I've been able to get is ~20-30 mesh/600 micron but I'd like to reduce that by an order of magnitude. I also begged some 50-mesh/300 micron PCL out of an industrial supplier but it too is not fine enough.
I don't know if any of you have ever tried to grind a thermoplastic but its a disaster. In a burr grinder it goes goey and gums up the burrs in zero seconds. In an impeller-type grinder (like a coffee grinder) it amazingly just bounces off.
I understand that standard practice is to cool the stock with LN2 to embrittle it. Do you think dry ice would be cold enough to do the same? I figure perhaps I could mix up dry ice and my subject material and just run it through the grinder all at once, then allow the ice to sublimate....?
Is it the glass transition temperature that I need to get below? For PCL thats -60C which means that dry ice (sublimation -78.5C) should be OK...?
Wed Nov 30 2011, 04:07AM
To get better thermal contact with dry ice, try a dry ice + alcohol bath. I have used one in the past when I need to chill things in a hurry (press fitting) and It's a lot cheaper then getting a dewar and some liquid nitrogen.
AndrewM
Wed Nov 30 2011, 04:15AM
I can't put anything moist into the grinder; its not sealed, the alcohol will drain into the motor.
Carbon_Rod
Wed Nov 30 2011, 05:37AM
Wax is usually a mixture of several compounds, and the oils usually used to "soften" crystal structure does not powder well.
Anything above -40'C would likely be insufficient to reliably break the physical structure into a fine dust.
Ultra fine vinyl or epoxy used in electrostatic powder coatings is likely available at a similar price.
Perhaps looking at Metal Injection Molding supplies may offer some options too.
AndrewM
Fri Jan 20 2012, 05:43AM
For the record...
Pic #1 is my starting material - this is a "carvable" injection wax from Kerr Lab.
Pic #2 is one dixie cup worth of wax prills, plus one dixie cup worth of coarsely chopped dry ice, ground in a standard issue coffee grinder.
Pic #3 shows the result - the volume is greatly inflated by the dry ice, which will sublimate slowly over the next few hours.
Pic #4 shows that dry ice does NOT work with PLA/polylactic acid - despite the high glass transition temperature for this material it remains ungrindable even at dry ice temps.
So there you have it - at least for some wax, dry ice enabled the creation of a very fine powder.
1327038195 49 FT129434 Wax
1327038195 49 FT129434 Grinder
1327038195 49 FT129434 Result
1327038195 49 FT129434 Pla
Carbon_Rod
Sat Jan 21 2012, 08:02AM
PLA is usually mixed with PDLA and or a 1/3 ratio cellulose composite...
Kinda like the hotdog-meat of plastics...
Perhaps atomized polymer solidification is possible:
Cheers,
AndrewM
Sun Jan 22 2012, 06:15AM
Carbon_Rod wrote ...
Oh! That makes total sense.
I got my PLA in filament form for use in 3D printers. I had been wondering why the manufacturer recommended setting the extruder to 200C, given that I thought PLA melted at only 50 or 60C... must be the PDLA.
