  • Guests: 30
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Tame fireballs via laser air/water breakdown?
Tue Nov 29 2011, 08:24AM Print
Hi all.
Just occurs to me that the latest 3-D "plasma" research uses water as a display medium.
It seems that the laser breakdown threshold for water is far lower than for air, and to make a bubble
which then flashes as it collapses (laser induced sonoluminescence?!) is a lot easier.
I think they also used ultrasound to initiate the breakdown and shim the ultrasound fields so it scans
the voxel space several times a second generating a flat sheet of discharges.
Recall the article about short lived fireballs from water when hit with a massive capacitor discharge via a shaped electrode?
Wonder if you could combine the two techniques to produce a laser plasma fireball from water, then apply enough RF energy
via a tuned field coil array (sort of like microwave plasma) and shim the fields to keep it in one place?
If salt water is used then the fireball would appear reddish-orange and could remain stable for tens of seconds in air.
As long as energy in > energy out then it should hold itself together with the aid of pressure from the atmosphere and
the strong poloidal magnetic fields present within the fireball itself.
Comments?
-A
Inducktion
Tue Nov 29 2011, 03:35PM
Isn't it sort of like that electrolysis by microwave radiation thing I posted some time ago? It split water into hydrogen and oxygen, and the heat created by the microwaves caused it to ignite...
radiotech
Wed Nov 30 2011, 08:01PM
How close is this to ball or globe lightning?
Wed Nov 30 2011, 08:34PM
It isn't, the fireball is acting as a breakdown region in much the same way as in the microwave case.
What is interesting is that it can be initiated in open air without a highly dangerous microwave field..
Maybe Tesla's "pet fireball" was this, or a thin glass inert gas filled sphere that floated due to being fairly hot?
