  • Guests: 35
SCR inverter (thyristor inverter)
zilipoper
Wed Nov 23 2011, 11:51AM Print
zilipoper Registered Member #4152 Joined: Thu Oct 20 2011, 10:18PM
Hi all.:-D
represents a generic device, do not kill SCR inverter:-D
supply voltage 400v DC
frequency-6-25kHz
SCR Russian thyristor ТЧ63-9
driver TL494CN
1322048777 4152 FT0 Sam 2594
1322048777 4152 FT0 Sam 2572
1322048884 4152 FT0 Sam 2560
1322048884 4152 FT0 Sam 2562
1322048884 4152 FT0 Sam 2564
1322048884 4152 FT0 Sam 2565
1322048954 4152 FT0 Sam 2563
zilipoper
Wed Nov 23 2011, 11:58AM
coming soon do not kill SCR Half-bridge inverter:-D
1322049497 4152 FT129041 Scr Induction Heating
Inducktion
Wed Nov 23 2011, 11:59AM
All I can say is, wow, those arcs are very nice.
They would be fantastic in a Jacob's Ladder.
Are you going to post a schematic of this, or are you planning on keeping it a secret? ;o
zilipoper
Wed Nov 23 2011, 12:18PM
pumped power ferrite add do not kill SCR Half-bridge inverter
at a frequency of 7kHz - 10kW
at a frequency of 15kHz - 23kW
at a frequency of 50kHz - 80kW
at a frequency of 65kHz - 100kW
scheme will publish later:-D
need to finish the scheme
1322050513 4152 FT129041 Sam 2472
1322050544 4152 FT129041 Sam 2481
1322050563 4152 FT129041 Sam 2491
1322050583 4152 FT129041 Sam 2499
1322050602 4152 FT129041 Sam 2509
1322050634 4152 FT129041 Sam 2513
Wed Nov 23 2011, 12:44PM
Excellent! smile
Can you please explain how the inverter works with only one SCR? How does the SCR turn off once it's been fired?
zilipoper
Wed Nov 23 2011, 01:09PM
Hi Steve8-)
single-ended converter
when the direction of current in the coil on the opposite, the thyristor is closed before the next pulse:-)
Daedronus
Wed Nov 23 2011, 01:54PM
That's a huge amount of ferite..... confused
what do you plan to use it for?
zilipoper
Wed Nov 23 2011, 01:59PM
yes 7kHz SCR inverter - 10kW:-D
Marko
Wed Nov 23 2011, 02:46PM
Zillipoper - OMG... the secondary on that transformer looks homemade as well? :O
How much power does the thing draw while making a 20cm arc? I would think you're overdriving the ferrite so much it would cook in seconds.
And if you really intend on constructing a HV transformer out of all that ferrite, where will you get 100kW+ required to drive it? O_O
Funny, I've got some big SCR modules too and wasn't even sure what to do with it. I was discussing with Steve about the possibility of wiring one in a series resonant circuit with a MOT at few hundred Hz so the thyristors get naturally commutated. Some current control scheme would be mandatory though to prevent the thing from blowing up :)
Marko
zilipoper
Wed Nov 23 2011, 03:11PM
hi Marko :8-)
Power arc 1500-2000W
secondary coil Russian flyback transformer cheesey
ferrite cold, secondary cold, SCR cold suprised suprised
ballast roasted cheesey cheesey
I will do 10kW SCR inverter 7- 10kHz
later try to construct SCR DRSSTC:-D resonant frequency 20-40kHz
