  • Guests: 42
ZVS driver with one gate disconnected...
Inducktion
Mon Nov 21 2011, 06:18PM Print
A while ago I noticed that the famous ZVS driver seems to work, and has some different characteristics when one of the gate resistors is left unconnected.
It seems to draw significantly less current, but works only at voltages under around 15 or so. (i think it might be due to the zener voltage? Needs moar tests!)
It also seems to work better with higher frequencies!
Anyone have any experience with this?
Newton Brawn
Sat Nov 26 2011, 05:18AM
Newton Brawn Registered Member #3343 Joined: Thu Oct 21 2010, 04:06PM
Induction:
Do you mind to sketch the ZVS and point out the resistor that is disconnected ?? Any more info re current draw will help
Regards
