  • Guests: 38
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
diode identification help
Matt Edwards
Mon Nov 21 2011, 02:51AM Print
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
Anyone want to take a stab at the specs for this diode? there are no markings on it except for the standard diode symbol...
here is a larger image Link2
1321843829 2838 FT0 Photo
Mon Nov 21 2011, 04:55AM
weLL,
--first, itll be high current you can be sure of that.
--second, youcan measure the V drop at the curretns of interest.
--third, you can figure out its polarity.
--Fourth, as for reverse V rating, your kinda screwed... unless you kniow what it came out of, or have multiple diodes you can spare, thus destructivly figuring it out.
well im drunk rIght know so donttake any of this seriously till others back me on it.
Matt Edwards
Mon Nov 21 2011, 01:50PM
Way to state the obvious Patric!
Haha, just kidding...
But seriously, being so large i was hoping that someone would recognize it by seeing it in an application or by brand maybe...
I know it is a long shot but its worth a try ;)
Mon Nov 21 2011, 07:25PM
Judging by looks alone can be problematic with most semiconductors.
I had a whole series of stud type diodes, they were all the same to look at, but had very diffeent specs.
The case can be exactly the same for multiple device types. without the part numbers, your kinda screwed.
Dr. Slack
Mon Nov 21 2011, 09:21PM
Patrick's post under the influence gets 3 out of 4. You're not entirely screwed for reverse voltage. Diodes will tend to avalanche when their reverse rating is exceeded, and most will avalanche without damage if you can limit the dissipation. Use a big series resistor to limit the current as you increase the reverse voltage and monitor the uA leakage current. Some might die on you straight, but hey, you didn't want to use anything that fragile anyway did you?
You might have a stab at the reverse voltage from measuring the forward drop, how many silicon PN junctions are there in series? If 0.7v (ish), there's only one, so it's not going to exceed 1000v, or if it does, not by much, and could easily be way less. If 1.4v or more, then there's several junctions in series to raise the reverse voltage to several 1000 or more. But looking at that package, I doubt it.
Matt Edwards
Tue Nov 22 2011, 01:56AM
Well, thanks guys. I'll just toss this thing in the corner for the day I'm desperate for something beefy. The. I'll take my chances from there tongue
Electra
Tue Nov 22 2011, 02:40AM
I would have taken a guess that its relatively low voltage, high voltage at high current would be quite a specialist part, so you might expect to see a maker’s brand name then. Possible applications could be from a welder, industrial battery charging, or dc motor drive.
You could compare the stud size and diameter of the hexagon; with other large stud diodes you can find data on to get you into the ballpark, for its current rating.
Voltage is more difficult to determine, I’d place my bets in the 150v – 400v range.
But Dr slack’s method above is a good way to carefully test it, it’s normal rated voltage will be a lot less than where it begins to break down, for reliability reasons of course.
