  • Guests: 41
High voltage discharger
ifryd
Thu Nov 17 2011, 07:43PM Print
ifryd Registered Member #4215 Joined: Wed Nov 16 2011, 09:45PM
Hi
This is my first post on this forum so I would like to say hi and welcome you all. I am happy that I can be part of this community.
I need your advice concerning my new project. I want to make let`s call it "discharger".
Basically what this circuit has to do:
Charge bank of electrolytic capacitors to the desired voltage (15 - 20 KV). Sum of capacitance of these capacitors could be let`s say 2.2uF or less.
Then I want to rapidly discharge these capacitors but what is more important I want to discharge them with precise frequency of intervals. I would like to adjust this frequency from 250hz up to 1200hz. (+-1hz)
Now after this short description I have questions concerning it:
1. What would be the best approach to the above problem?
2. How to switch with precise frequency (+-1hz):
a) by adjusting PWM of the high voltage supply?
b) by using rotary switch?
3. What is the maximum switching frequency of the static and rotary switch?
4. How loud can be these discharges?
5. How to get rid of the ozone problem completely. How do you deal with it? My first approach was to drill holes in jar and the make discharges in jar. Would be a good idea to build case for rotary switch ?
6. what source of power supply would be the best? Flyback driver or high voltage transformer ? Maybe I should consider also tesla coil but can secondary widing be tuned to a desired frequency (+- 1 hz)?
Adam
Thu Nov 17 2011, 08:26PM
Adam,
2.2 uF at 15 kV is 247.5 Joules, at 20 kV it's 440 Joules.
So 250 Hz = 61.875 kW to 110 kW
at 1200 Hz that is 297 kW to 528 kW
... maybe a re-think is in order ?
Forty
Thu Nov 17 2011, 08:44PM
edit:
apparently sulaiman was typing out the calculations at the same time i was.
A Marx generator might be what you are looking for.
its discharge frequency could be controlled by the input current.
although for 250+Hz repetition rate you'd probably want a cw multiplier or a switched hv transformer.
an ignition coil fed by a square wave might work.
To paraphrase the quote from Jaws: You're gonna need a bigger jar.
ifryd
Thu Nov 17 2011, 09:03PM
It is not a problem I will change this capacitance from 2uF to 2nF or even less. Nothing is predetermined here. You concentrated about capacitors and what about other questions ?
jpsmith123
Thu Nov 17 2011, 10:13PM
It's not clear exactly what you want to do. If the capacitor is being fully charged and fully discharged hundreds of times per second or more (as your description seems to imply), then as Sulaiman pointed out, you're talking about a ridiculous amount of power. You need to clarify; are you trying to drive some kind of load?
Fri Nov 18 2011, 02:13AM
ifryd wrote ...
We have to respond to your other questions with more questions.
What discharge time do you require?
Where is the C*V^2/2 energy supposed to go when you discharge the HV cap?
You sort of implied a spark in air. Is that necessary, for example as a stroboscope lamp?
Then why not say so? It would direct us toward spark-gap quenching and triggering ideas.
Do you want it to be relatively quiet and dark?
How about discharging the capacitor into a resistor, perhaps switched by a high voltage thyratron? (now the circuit is starting to look like a radar pulser). Then you can change the resistor value to trade between peak current and discharge time.
Could your application use a pulse shaping network?
Newton Brawn
Fri Nov 18 2011, 05:51AM
Newton Brawn Registered Member #3343 Joined: Thu Oct 21 2010, 04:06PM
Ifrid:
Ia...
You must explain the purpose of your project to have the chace of receive good answers.
Make a schematic, a drawing, clarify your proposal
Regards
Newton
ifryd
Fri Nov 18 2011, 09:41PM
Hi I want to make device to test so called "disruptive discharges". So basically I want to trigger rapid discharge of high energy. Now switch can have delay time of triggering it is not a problem but should switch high energy as fast as possible.
Thanks Klugesmith for giving me idea about thyratron. I searched internet and I found this good article about high power switches http://205.243.100.155/frames/pasley.html
I also found manufacturer of various switches http://www.rell.com/Pages/Product-Category.aspx?productCategory=12
What do you think about triggered spark gap switches. I think this is basically what I need.
I want to send as much energy as I can in the shortest time. As far as I read triggered spark gap switches have time of switching equals 2ns.
What I want from switch is to stop giving ozone and stop giving UV radiation. So in other words should be safe for operation. Yes it would be good if switch could be quiet. Is it possible when switching high energies ? What would be better thyratron or triggered spark gap? What voltage is needed to switch on triggered spark gap switch?
Below I am attaching figure:
1321652265 4215 FT128622 Hv
GrantX
Sat Nov 19 2011, 06:44AM
From a cost, practicality and expense viewpoint, you should look into using one or two PIO pulse capacitors, rather than an electrolytic bank. First of all, I don't think an electrolytic bank can do sub-micro second discharges, secondly, to build up a reliable 20kV bank you will have to spend big money.
For example, in the pic below I have 2 capacitors. The big pulse capacitor is 50kV 100nF (perfect for your application), and cost me only $50 dollars on ebay. It's in perfect condition, very tough, and can discharge a lot quicker than electrolytic caps.
The blue electrolytic is 450V 1900uF and cost $39. You would need 112 of these to match the 50kV rating of the pulse cap.
1321684586 4074 FT128622 Imag0119
As for switching, perhaps just a shielded rotary spark gap using a synchronous motor driven by a VFD?
like this:
