  • Guests: 43
Measuring very low resistances
FastMHz
Fri Feb 17 2006, 06:21PM Print
FastMHz Registered Member #179 Joined: Thu Feb 16 2006, 02:08AM
Location: Hagerstown, Maryland - Close to Prime Outlets
Hi all...I need some suggestions for ways to measure very low resistances, such as those of small coils. My multimeters only go down to tenths and display all zeros...I need hundreds and thousandths.
Has anyone used the 4 wire method that could explain more about how to perform it?
All ideas greatly appreciated!
Eric
Fri Feb 17 2006, 07:26PM
Eric Registered Member #69 Joined: Thu Feb 09 2006, 07:42AM
The four wire method simply means that you seperate the current source and the voltage measurement circuits so that any voltage drops in the current source circuit don't effect the voltage measurement accross the test peice. That way you can measure only the voltage drop (and thus resistance) across the test peice.
You could do this very simply without building anything if you have a current regulated power supply. For example, if you hook up a 10A current regulated source to your coil and then measure the voltage across the coil with a standard multimeter, you'll have a quick and dirty four wire scheme. In that instance, each millivolt on the meter equals .1 milliohms of resistance in the coil.
FastMHz
Fri Feb 17 2006, 07:33PM
Interesting...I'll have to see if I have such a supply...if I don't, would something like shown in the schematic work?
1140204832 179 FT1285 Mhz Lowrestest
The reason for such a low power source as a AA is because my ammeter only measures 10amps max.
Eric
Fri Feb 17 2006, 07:48PM
An AA will put out around 10 amps, short circuit (which is what this is) but only for a little while and at some risk of explosion. They aren't made for that and the current won't be constant. Any constant current supply will do.
In your schematic the voltmeter should be connected across R, assuming that's the coil you are testing.
FastMHz
Fri Feb 17 2006, 07:54PM
10 amps, eh? Maybe a AAA would be better? I don't have a constant current supply...just an old radioshack 3amp regulated supply but it's certainly not accurate enough for this. The battery would be shorted for just a second or so, just long enough to read both meters. It shouldn't even get too warm I wouldn't think. I see the error in my schematic - thanks for pointing that out...if I did this test, would it theoretically work?
Eric
Fri Feb 17 2006, 08:29PM
Sure, in theory. But I have a feeling that the battery will change in current significantly during the test, it droops off significantly in the seconds after you first hook it up. If you can get a stable current measurement AND voltage measurement at the same time then you are set.
Does that radio shack supply have current limiting? If so, use that instead. (post a pic if you're not sure)
Fri Feb 17 2006, 08:36PM
Just curious, why the need to measure such low resistances? What is your application?
FastMHz
I doubt it does...here's a pic:
1140208613 179 FT1285 Mhz Powersupply
I want to know the resistance of my ring launcher and coilgun coils so I can estimate the surge current through my SCRs...or am I making a simple thing hard?
Eric
Fri Feb 17 2006, 08:39PM
No, you're right it doesn't... You could always hook a low value resistor in series with that supply (like 1 ohm / 10Watt) to get a reasonably stable current source.
FastMHz
Fri Feb 17 2006, 08:40PM
The resistor in series with the power source if a great idea...that should help a bit and eliminate the need for batteries wink
UPDATE: ok, I did some real testing and ended up using AAs instead of the power supply because I was really afraid of blowing my ammeter. The results sound about what I would have expected too. I took two measurements and averaged them:
1st - 1.111a, 41.8mv
2nd - 1.07a, 39.7mv
Average - 1.0905a, 40.75mv
Resistance of coil - 37.37 milliohms
So...if I feed it a pulse of 700v the max that would go through the SCRs, assuming the caps can deliver, is 18731.6 amps.
My SCRs are 3 in parallel and accourding to datasheet can handle 30ka in 10ms pulses. Assuming this test was somewhere near accurate, my SCRs are not at risk.
