  • Guests: 58
Plasma speaker from rectified mains.
M.A.D.
Sat Nov 12 2011, 05:09PM Print
M.A.D. Registered Member #4052 Joined: Thu Aug 11 2011, 04:43AM
I do not know how to do the math to see if this is a bad idea, so I could use some help.
I am plannig on building a speaker based on the design here http://www.teravolt.org/sparkspeaker2.php. However it requires huge caps for the bridge and a rather large step down transformer to power it. Both of these increase the size and expense of the speaker. Since the MOSFETs are rated at 200v anyway I was thinking it would be easier just to rectify and filter 120v mains.
I am also going to add hyperfast freewheeling doides and schottkeys to protect the MOSFETs from kick back, and I am going to reduce the gate resistor and put a UF diode in parallel with it to reduce the time that the MOSFETs are linear. I am also using IRFP260s instead because they are better.
So is there any reason why I should not do this? How large would the bridge caps need to be? And how can I tell how many volts per turn a flyback is good for?
Adam Munich
Sun Nov 13 2011, 02:04PM
It will work, but I'd use 600V mosfets or IGBTs. The capacitors can be small, but they must be 400V ones.
You *must* keep the primary coil's impedance high (with many turns).
170 volts / 2 == 85V going to the primary.
85 / 6 turns == 14V/turn, way too high for a small core.
85 / 20 == 4.25V/turn. That's more like it.
M.A.D.
Sun Nov 13 2011, 06:53PM
Thank you very much for your help.
Do the MOSFETs have to be rated higher if I use UF freewheeling diodes in parallel and schottkeys in series with the MOSFETs, to protect them from kickback? I can get 500v MOSFETs but the Rds(on) is a lot higher (0.27 instead of 0.04), so won't they run hotter?
Also how can I find how large the caps need to be? Is there an equation or something?
Adam Munich
Sun Nov 13 2011, 06:57PM
Well 1 amp at 85V is 85W.
1^2 * 0.27 == 0.27W lost.
2 amps at 85V is 170W.
2^2 * 0.27 == 1.08W lost.
3 amps at 85V is 225W.
3^2 * 0.27 == 2.48W lost.
4 amps at 85V is 340W.
3^2 * 0.27 == 4.32W lost.
RDSon will likely be one of the smallest losses in the system.
M.A.D.
Mon Nov 14 2011, 12:31AM
All right, thank you, since there is almost no added loss, I will use the higher voltage MOSFETs.
Do you think that 470uF is too small for the bridge caps?
Once again, thank you for your help.
bomber315
Wed Jan 28 2015, 07:01PM
bomber315 Registered Member #43257 Joined: Thu Feb 20 2014, 03:53PM
im curious how far this project got/ how successful it was.
Adam, i am hoping to make a mains powered version of your circuit. Have you ever tried it that? Do you have any revisions to the widely found diagram?
Newton Brawn
Sun Mar 08 2015, 02:25AM
Newton Brawn Registered Member #3343 Joined: Thu Oct 21 2010, 04:06PM
I Adam !
Fix the math
3^2 * 0.27 == 4.32W lost. ??
Regards
Adam Munich
Sun Mar 08 2015, 07:10AM
Blast from the past?
