  • Guests: 55
Is this capacitor for real?
kimbomba
Sun Mar 15 2015, 11:41PM Print
kimbomba Registered Member #3854 Joined: Fri Apr 29 2011, 03:45AM
Consdering the ratings, 3 Kv, 100 uF and a price of $144, sounds too good to be true
Antonio
Mon Mar 16 2015, 02:09AM
Seems impossible. Maybe much less capacitance or much less voltage.
GrantX
Mon Mar 16 2015, 04:55AM
It could be correct, considering the dimensions of 120mm x 123mm.
For comparison, I have a few oil-filled defibrillator capacitors from General Atomics which aren't any bigger at all, but they are rated 2kVDC (3kV surge) and 110uF. They are rectangular and roughly 120mm x 100mm x 75mm (I'm not at home so they're just ballpark figures). These caps were less than $50 each, sold on eBay as "new old stock."
The stated 3kVDC rating is probably the absolute upper limit. For a reasonable safety margin I would consider that to be the "surge" rating, and probably wouldn't ever push them beyond 2kV.
Antonio
Tue Mar 17 2015, 01:20AM
GA has really some quite impressive capacitors. Link2
Hazmatt_(The Underdog)
Tue Mar 17 2015, 04:25AM
For starters, its not pulse rated, that's just the voltage rating before it will start having leakage issues.
GammaRay
Sat Mar 21 2015, 02:43PM
GammaRay Registered Member #5323 Joined: Fri Jun 15 2012, 02:14PM
I've made several satisfactory purchases from that vendor... not that particular cap tho.
Signification
Sun Mar 22 2015, 01:26AM
These are on ebay for over $200! and I thought it was a sale. Something about it always catches my eye.. but $144 !! Now I would look for the data sheet on it.
