  • Guests: 46
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
P-channel mosfet Buck Converter...
Inducktion
Wed Nov 09 2011, 04:42PM Print
I understand that with a regular buck converter, it requires high side gate driving techniques...
Would it still be needed with a P-channel mosfet in it's place? And how would you go about driving it anyway, since it needs to be all negative and whatnot.
Like this, could I just use that with a SG3525, or something similar to make a buck converter? (no high side chip needed, apparently!)
Thanks!
Mattski
Thu Nov 10 2011, 08:17AM
wrote ...
With a p-channel you can use low-side driving, though the voltages involved can still be quite large if you have a high input voltage, so make sure to check the Vgs,max rating. You don't need negative voltages, just negative polarity: A positive gate voltage equal to the input voltage (applied to the source pin of the FET) will turn it off. A zero gate voltage will turn the FET on. You need to check the Vgs,max rating for the on-state, because if you have a 25V input on the source, 0V on the gate, you have Vgs=-25V which is pretty big.
Some switching regulator control chips are nice enough to provide you a gate waveform of both polarities, but the most common output will be for driving the N-channel MOSFET. You can convert it for use with P-Channel MOSFETs by running it through an inverter.
